over fill my transmission
    I accidentally over fill my tranny with honda OEM fluid. My tranny is slipping and I had to replace my ecu, blown capacitor. Its still slips no gears. Looking to correct or trouble shoot this issue before I go I yank another tranny from the junk yard.
    Thanks
    I’m assuming this is for an auto? As I don’t know how you can over fill the manual trans as once it starts seeping out the fill hole you stop.
    ~Nick~
      If it is too full, either suck some out through the fill hole, or drain it and fill it correctly. Do you mean you replaced the Transmission Control Module (TCM)? How many miles on the transmission? How often have you replace the fluid in the past?
      Getting one from a JY can be a crap shoot as well, you don't know that the one you're getting is any better than what you've got. That's a lot of wasted work if it doesn't work.
        its an auto. It was the TCM i had to swap out. I just had an extra quart of OEM trans oil so i just decided to drop in just because i had it. I wish i did would of not drop the fluid it. will this correct the issue?
          How did you go about checking the fluid level before topping it off? I'm hoping you did this before adding your fluid.
          My '91 LX build. Bought September 2017. Sold June 2020.
          http://www.cb7tuner.com/vbb/showthre...r /> t=209871
            I cannot lie, I just bought an auto EK Coupe & I was changing the shift solenoid
            towards the bottom of the trans. Like an idiot I removed the sensor & fluid
            poured out as swapped on the new sensor (terrible idea). I eyeballed how
            much I thought poured out & it ended up being too much. It wouldn't even
            move in Drive.
            I just drained it all then just refilled the proper amount & it was fine
            afterwards.
            Keep Pushing..
              Gonna drain and refill to spec this weekend and see what happends. Will post up.
                Solid advice in here already. Nothing SS needs to add.
                The Lord watches over me!
                "Stop punching down on my people!!!"
                - D. Chappelle
                  Drained the fluid out, I caught about a gallon and quarter. It was still cherry red, ran it only for a day or two, no clutch material and the magnet plug was still clean.
                  So how many quarts do i put in from bone dry?
                    Start with about 2.5 quarts. Drive it around the block. Check it. Add maybe a little more depending on what's on the stick.
