I have my Intake Manifold off with plenum still attached and the throttle body also. It is really necessary to remove throttle body to clean it. Are there some ports that can only be cleaned with it removed. Am also wondering if it is necessary to remove plenum. I don't think it is as i had plenum removed about a year ago and cleaned it. Thoughts?
IM off. Should i remove TB To clean.
it never hurts to clean things, but you should be fine.
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
At least remove the idle screw and clean that port in the throttle body. Clean the throttle body plate as best you can if you decide not to remove it. The gasket is fairly inexpensive, I would remove the TB and clean it while I had the chance.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by fleetw00d View PostAt least remove the idle screw and clean that port in the throttle body. Clean the throttle body plate as best you can if you decide not to remove it. The gasket is fairly inexpensive, I would remove the TB and clean it while I had the chance.
