Ok here is the deal. I have been having this problem when I go to beat on my H22. Every time I got to get the fuck outta somewhere, it will basically lose all power almost like the injectors cut off and won't catch back up until I let off the gas and slowly mash it again. When I peg it out in first, it will accelerate like a boss as normal and then when I shift it into second then press the gas, I have nothing until I left off and slowly press back in and then it will keep on taking off. It usually does this on the interstate when I am switching from 5th to 3rd and once I punch it in 3rd gear, NOTHING.
Now I do feel a SLIGHT skip when I accelerate. It just doesn't feel smooth. But I want to say thats in the chip. I have new ignition components except for dizzy. Also, my gas mileage is all over the place. Some times I can get 32, and other times I will get 26 and driving conditions are all the same.
I recently tested the TPS when I installed the engine and I used a known working one, but I haven't tested it since it happened. The o2 sensor has a bit of age on it, but its only seen 3000 miles of actual use. It was there when my ecu didn't use it, but when I installed the swap, I made sure the chip had the o2 sensor turned on.
My question is, what usually causes this issue? Has anybody experienced this before?
EDIT: I have a new fuel filter on it as well.
