The freaking verdict is in. Just got consulting with a very credible source, whom told me I will not be able to smog the my car with F22A6 by legitimate means in California. So not being street legal issue would come into play?
short block replacement
Hmm I've been watching your post. I'd say you would still be legal just switching the block even the whole engine. As the F22A1-A4-A6 all were original engines of these cars just different models to match different trim styles I myself think you would be good at SMOG.
Because yours is a 1992 if you don't have a LX sign on your trunk lid just tell the smog tech its a EX LOL well I honestly don't think its gonna matter its not like your putting in a engine that wasn't stock to the cb7'sLast edited by Kev1990; 07-29-2015, 04:27 PM.
Thanks Kev, ur a guru. Im was busting my nuts last night loosing my precious sleep over this. I live in a tree hugging California, & its becoming more & more like a Nazi state. I like our way of thinking, Im gonna have say "YES" to all to the above. I got one of my own to tell the douchebag smog technician, "that's the way I purchased the care.
This is a no brainer, gonna get A6
Originally posted by EsperHamid View Postwhat advantage do short blocks have ?! aren't they better for city driving rather than highways ?
Originally posted by EsperHamid View PostOh, he's buying only the block so he refers to it as short block ?! ...I thought it had shorter cylinders. I was confused my bad.
Edit.. Looked it up and want to delete this post, but I will wear the dummy hat. Some of my earlier post are based on my misinformed prior knowledge.Last edited by cb7 calling; 08-13-2015, 09:42 PM.......father in law has it back again. Time to shine
just to share my experience, I burned my original F22A4 engine when I first bought my cb7 (long story). So my dad went ahead and bought an engine which they told him it was the same, later on I found out from the forum that it was an F22a6 cause it had an oil cooler.
back then I asked the mechanic who replaced the engine to put my original IM and Exhaust from my late F22A4 ( well I wanted a memory of that engine )
The point here, is that later on when I wanted to replace the IM gasket, I had to make it by hand ( difficult I know ) but that's because I found out there's a slight difference in size between the runners of the IM (f22a4) and the mating IM entries of the f22a6 head.
so take the time to observe the parts before installing them.
EsperHamid, Thanks its that kind of detail im looking for. Anyone, have that list of compatible cars that have the f222a6?
Swapping in a f22a6
f22a1 parts: to be slap on the f22a6:
(IM), (EM), cylinder head, water bump & timing belt (installed last May)
f22a6 parts: short block, cam & valve springs.
So if Im keeping my f22a1 (IM), exhaust, and Cylinder head, what gastkets do I order, or do I simply get the F22a6 (IM) with the black box? Do I get the f22a4 exhaust? Im planing on getting the f22a6 cam & valve springs.Last edited by Jarrett; 08-17-2015, 12:01 PM.
