honda mtf in 92 accord ex??
    i have a 92 accord ex MT. Im going to replace my front right drive axle and before i do i wanted to know if its really ok to replace my old tranny oil with Honda MTF.
    I don't see why not.
    Id encouage you to change it.
    DONT FLUSH THE TRANNY!!!!
    Just drain and refil. You can get a new washer, and make sure you clean off the plug as it's magnetized and has metal shavings iirc.
      By plug you do mean drain bolt and filler bolt?
        That's what he means. If you are replacing an axle, it would also be a good opportunity to replace the axle seal in the transmission.
          ok thanks guys. i will let you all know how it turns out..
            You know he was reffering to a Manual trans aye?
            To the OP - Honda MTF is fine to use.
            If you don't know when it was last changed you may as well drain the whole lot and refill with Honda MTF.
            My 5.7 LS1 Holden Ute
              OEM parts and fluids.
              Project:Black Skittle
              AOM->April 2014
              MRT->http://www.cb7tuner.com/vbb/showthread.php?t=199779
                Ya I did, do they not have the magnetized plug?
                I couldn't remember if that was only auto's.
                If not did I give bad advice?!?!? LOL
                  No bad advice; I was more wondering why you said, "DO NOT FLUSH THE TRANNY!!!"
                  It a manual trans.
                  #1 - I've NEVER heard of flushing a Manual.
                  #2 - There is NO reason why flushing a Manual would be an issue.
                    GM Synchromesh is also frequently used with good results. I use it myself.
                    Either way, quality fresh fluid is the best way to keep your transmission healthy. Too many people neglect their transmission fluid.
                      with the honda mt is it safe to run slick 50 in it?
                      this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
                      Car safety checks
                      Fluid Capacities
                        Slick 50 is an additive, right? You should never add anything to your transmission fluid. (or your engine oil for that matter.)
                          Good advice. The only time i would try an additive is for a trans to limp it to where i can work on addressing the problem.
                          02 Crv
                            Right. And at that point, the trans is probably shot anyway.
                            I'll put anything into a failing engine or transmission if it'll get me home without a towtruck!
                              I know its been beat to death, but I believe your driving style and what you do with the car has alot to do with which lube you should use in the trans.
                              I race my car regularly, i run 10w-30. If its a grocery getter, you should def go with syncromesh or mtf. A lil of both, use a quart of mtf and a quart of 10w-30.
                              I change my trans oil regularly and have had zero issues reliability wise. I does make it hard to put in low gear, 1 and 2, when cold. Half and half is a good comprimise if youre not drag racing a few weekends a month without changing the fluid out.
