Go Back   CB7Tuner Forums > Beginner forum -- New members post here! > Beginner Appearance
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 10-27-2012, 02:02 PM   #21
deevergote
Don't call me dude.
You never spray the glass.
And no stock CB lights come blackhoused. The procedure is the same for all.
Old 10-29-2012, 01:20 PM   #22
granittoCB7
granittoCB7 is cool... so far.
Originally Posted by erknee916 View Post
Would you do the same method on 1-piecers? or do some come black housed?
Yes, however if you have a set of one piece headlights i wouldnt recommend doing this DIY because one piece headlights are usually pretty dope to begin with.
but if you did want to then yes its essentially the same thing. just be watchful for the oven times, the taping, and the yellow highbeam.
taping would be a little more difficult considering you may not know what to tape exactly. Just always leave the reflective part behind the bulb chrome and you shouldnt have an issue.
also some one piece headlights have a chrome lip around them which may not be possible to remove without damaging it. Im unsure but i wouldnt mess with those.
granittoCB7 is offline   Reply With Quote
Old 10-29-2012, 01:24 PM   #23
granittoCB7
Originally Posted by buzz11 View Post
I remember reading somewhere that spraying your bulbs is a bad idea. But then again its your high beams, you wont use it too often.
ya it definitely is a bad idea which is why i said use a spare set and that it was a sketchy alternative.
i dont recommend using painted bulbs as a reliable function just because the integrity of the bulb is compromised when it heats up.
im doing it because i was so excited i finished my project that i decided to use my spares to get more of the yellow effect.
Old 11-04-2012, 12:25 PM   #24
thestockcb7
thestockcb7 is cool... so far.
Originally Posted by JFrost7 View Post
I'm not sure if it's been asked before, pardon me if it has, but if I didn't want to blackhouse my headlights and only stain glass yellow the high beam side, would I only have to mask off the high beam side and spray the glass yellow?
In your case, I think it would be easier to just apply yellow vinyl film to the high beam side, instead of opening them up and spraying them. Kinda tacky in my opinion, but it works.
thestockcb7 is offline   Reply With Quote
Old 11-05-2012, 07:53 PM   #25
ziggheat
ziggheat is cool... so far.
Yo good DIY im actually considering doing it myself now.
ziggheat is offline   Reply With Quote
black , diy , headlight , high beams , housing
