Closed Thread
Old 04-08-2012, 01:58 PM   #1
jaemil369
jaemil369 is cool... so far.
obd2 engine in 91 cb7
Simple, how do I do this? What will I need? Sorry can't search forums from phone
jaemil369 is offline
Old 04-08-2012, 02:24 PM   #2
Joey GT-R
Super Moderator
Joey GT-R has a HUGE cock! Joey GT-R has a HUGE cock! Joey GT-R has a HUGE cock! Joey GT-R has a HUGE cock!
Send a message via AIM to Joey GT-R Send a message via MSN to Joey GT-R Send a message via Yahoo to Joey GT-R
Search when you get home.....
A conversion harness to start, along with a compatible ECU.
'94 JDM H22A: 178whp 146wtq
Originally Posted by deevergote
Joey GT-R is offline
Old 04-08-2012, 02:29 PM   #3
jaemil369
This is my access to internet. What ecu do I need? And I thought the conversion harnesses where for older engines in newer cars not newer engines in older cats???
Old 04-08-2012, 02:32 PM   #4
deevergote
Don't call me dude.
OBD1 distributor, injectors, and ECU.
deevergote is offline
Old 04-08-2012, 02:33 PM   #5
SNOOZE
Location: LA-OC-SD Southern California, Beach Lifestyle!
SNOOZE is cool... so far.
We need more information to help you out. What obd2 motor are you trying to swap?
SNOOZE is offline
Old 04-08-2012, 02:40 PM   #6
TracieS
TracieS seems to have made some friends! TracieS seems to have made some friends!
This is it nothing else to it lol
STANCE|WORKS
TracieS is offline
Old 04-08-2012, 03:03 PM   #7
jaemil369
Its out of a 98 accord lx vtec. So I guess f22b vtec, correct?
Old 04-08-2012, 03:30 PM   #8
Joey GT-R
Super Moderator
False. F23A1.
Old 04-08-2012, 03:41 PM   #9
illinois_erik
you could tether your phone to your computer and use teh intarwebs that way
illinois_erik is offline
Old 04-08-2012, 07:17 PM   #10
jaemil369
Correct you are f23a1 or a4. So my? Is, what will I need for this swap. I know I need a 0bd1 vtec ecu which can be found from a 95 accord. Feel free to correct me. Thanks
Old 04-08-2012, 09:53 PM   #11
deevergote
Don't call me dude.
There is no OBD1 equivalent ECU for the F23A.
Old 04-08-2012, 10:58 PM   #12
jaemil369
Ok I figured that prob out. Anyone know what the deal is with the fuel rail? Some say it wont work others never mentioned it
Old 04-09-2012, 09:50 AM   #13
deevergote
Don't call me dude.
I believe the fuel rail is the same for all F and H engines.
Old 04-09-2012, 11:34 AM   #14
SOHC-FTW
SOHC-FTW seems to have made some friends!
The fuel feed line & banjo nut is on the passenger side for the f22a's fuel rail as to where on the f22b/f23 it is on the driver side. When i had a f22b1 my fuel feed line had to be extended, but you should be able to inter change the rails between the engines with little to no modifications.
02 Crv
SOHC-FTW is offline
Old 04-09-2012, 02:00 PM   #15
deevergote
Don't call me dude.
The JDM H22 has the same issue, with the feed on the other side. The easiest way to correct that is to just use the F22A rail. It's the same size.
Old 04-09-2012, 08:45 PM   #16
jaemil369
Thanks deevergote, that's what I was wondering. I picked the f23 up today. Other than the cracked valve cover it looks pretty good. I'm gonna go ahead and do the 5sp swap since its all gonna be out and I have everything (except drivers manual cv)
Old 04-09-2012, 08:49 PM   #17
deevergote
Don't call me dude.
You'll need to weld in the manual transmission mount bracket, or use a conversion mount from ESP. Overlook that step, and you'll be breaking axles like crazy.
Old 04-09-2012, 09:23 PM   #18
jaemil369
My buddy that I got the swap from said to drill a new whole since the mount is already onto it. Would that work?
Old 04-09-2012, 09:25 PM   #19
deevergote
Don't call me dude.
Both things are necessary. Drilling the new "whole", and swapping the mount bracket (or using a conversion mount.)
Trust me. I don't type things just because I like the sound of my keyboard.
Old 04-09-2012, 09:42 PM   #20
jaemil369
So just drilling the whole for the bracket and bolting it up alone wont work? Ill have to have it welded still?
Closed Thread
engine , motor , obd1 , obd2 , swap
