Thread Tools Rating: Thread Rating: 51 votes, 4.78 average. Display Modes
Old 03-07-2015, 10:20 AM   #681
802cb7
802cb7 is cool... so far.
How do you like the headlights on the white accord?
802cb7 is offline   Reply With Quote
Old 03-26-2015, 03:37 AM   #682
P5ylance
P5ylance is someone to admire P5ylance is someone to admire P5ylance is someone to admire
omg i loved them, cant wait to reinstall them on this black one!! cutoff was pretty good, and they were reallu nice circles... just really good build quality headlights!!
P5ylance is offline   Reply With Quote
Old 04-12-2015, 12:03 PM   #683
802cb7
Good, I finally found a place that has some. I wanted the all chrome ones like yours but I guess those have been discontinued for quite some time now. So I'mm getting the black housed ones. I like the factory look of them. Are they glass? Mine should be showing up any day now, I also ordered an H.I.D. kit to go with them. Funny, I remember when you could walk into advance auto parts and buy these off the shelf ca. 2002 lol. idk, they seem legit.
Old 06-04-2015, 01:17 PM   #684
P5ylance
for those who follow my thread, here's a treat. CD rear lower control arms and toe arms are a direct fit. You must use both the toe and control arm from the 94-97 accord for it to work. They are longer than CB arms.
Old 06-04-2015, 02:34 PM   #685
Jarrett
How is this a treat? I thought people knew this.
I'm assuming this is being touted for stance purposes.
Old 06-05-2015, 02:29 AM   #686
P5ylance
people are afraid theyll bind. those people didnt grab the toe arm as well. if you use both, youre golden.
well, stance yes, but they do have their merit. im using them to increase my track width in the rear, and as long as you correct the negative camber by extending your upper control arm via some form of kit or washer, you will have a wider track width. i rolled my fenders flush, corrected my camber maxed out that the inner wheel well has clesrance for, and im still slightly negative after 3 washer stack and spc camber kit. thats how effective these arms are in improving the rear wheel base.im at 5.37mm left of gap between my 17x7 +35 wheels, just right for a 5mm spacer.
and no my wheels aren't butterflied out, i aim to run no more than -1.5 camber if i can help it, im shooting for -1
Old 06-05-2015, 02:31 AM   #687
P5ylance
its a treat because im confirming that all you need are the arms themselves and it all works. you dont need the knuckle, you dont need the trailing arm, you dont need the subframe. you keep all your CB stuff and just swap the CD arms. i checked the trailing arm part numbers and theyre the same.
Old 06-05-2015, 02:38 AM   #688
P5ylance
yeah, width increased about 1inch per side. thats an additional 50.8mm of track width. cant wait to feel the effects on handling
Old 06-05-2015, 08:02 PM   #689
Lucien
Lucien is cool... so far.
Send a message via AIM to Lucien
Lucien is offline   Reply With Quote
Old 06-05-2015, 08:12 PM   #690
Jarrett
I had 3.2TL rear knuckles that give a track width increase of 30mm in the rear as the hubs are 15mm taller on either side. Going from a 14mm Accord sway bar to a 16mm Vigor rear sway bar with urethane mounting bushings gave a much more noticeable difference in the behavior of the rear suspension than the track increase did. I don't even know if I felt anything considerable at all.
Old 06-05-2015, 08:32 PM   #691
domesticated
domesticated seems to have made some friends!
Those rear knuckles probably make it easy to fit the TL 17x8s right?
'93 H22A 5SPD SE - MRT - DIY-Turbo Sizing - Chassis Dynamics Data
domesticated is offline   Reply With Quote
Old 11-20-2015, 02:30 AM   #692
P5ylance
Old 11-20-2015, 07:12 PM   #693
Mike1357
Mike1357 is cool... so far.
This car looks fantastic! I think everything flows better on the black car.
Mike1357 is offline   Reply With Quote
1992 , accord , bippu style , p5ylance , vip
