Thread Tools Rating: Thread Rating: 50 votes, 4.70 average. Display Modes
Old 08-01-2012, 10:17 AM   #241
Raf99
Originally Posted by Smokinspeeds View Post
Yeah there is a local shop asking 100$ new but they have gone up on eBay. See I have the same issue, mine came with the Philips bulbs and eBay kits are for non d2s headlights. Someone told me to get an eBay kit but didn't give me details on the socket so that's my biggest issue.
Ya, there's no way the 9006 socket type will fit in the units which kind of sucks as I have a 8000K kit and a 4300K kit still in box. Judging by the instructions and Function>Form's pics you remove the 9006 plug/socket to adapt for these units (which take a whole new bulb type). & I'm pretty sure the bulbs made for these are 100x better than what I have now.
Old 08-01-2012, 11:21 AM   #242
Smokinspeeds
Smokinspeeds seems to have made some friends! Smokinspeeds seems to have made some friends!
Send a message via AIM to Smokinspeeds Send a message via MSN to Smokinspeeds
Yeah I'm guessing D2S bulbs which are pretty much the gold standard for HID factory bulbs. Kits are just over 30$ shipped, you could get one then just use the wiring, then you will have backup ballasts, or you could use them for something like foglights?
Smokinspeeds is offline   Reply With Quote
Old 08-01-2012, 01:22 PM   #243
c91bse7
c91bse7 is cool... so far.
You need d2s bulbs and adapters if you already have a hid kit
Bulbs
http://item.mobileweb.ebay.com/viewi...id=08570141026
Adapters
http://item.mobileweb.ebay.com/viewi...id=62281282703
That's all I needed when I put my e46s projectors in and I will be getting some for my mini d2s as well .
Originally Posted by Darkcloud View Post
Wimp go low or go home haha
Originally Posted by cb7_tillidie View Post
Not a single fuck was given that day.
c91bse7 is offline   Reply With Quote
Old 08-01-2012, 03:07 PM   #244
islandhopper
islandhopper seems to have made some friends! islandhopper seems to have made some friends!
Depending on the HID kit you already have, you may just need an adapter. I had an existing kit that used 'amp' type ballasts. So i used the Amp to D2S adapters from TRS. Literally plug'n'play. TRS has EVERYTHING you need. I wouldn't go anywhere else. They are willing to discount for bundles as long as you ask. And their customer service is second to NONE.
The only thing i wouldn't get from them are the new Phillips 4.3k D2S bulbs. There is an eBay seller with awesome rep that is selling authentic phillips bulbs for around $60 a pair, which is $25 cheaper than TRS.
I have pics of my set-up if you need them to help you visualize.
Form.Follows.Function
islandhopper is offline   Reply With Quote
Old 08-01-2012, 07:44 PM   #245
Raf99
I should read before asking stupid Qs, but the adapter will only allow the ballasts to work with other bulbs for the connection type. There is still the issue of the bulb (with the 3 locking tabs) not fitting into the projector itself. My understanding is that only a certain type of bulb will fit into this (DS2 bulb) and then use the adapter to allow different ballast to work with those bulbs. Sounds like a headache waiting to happen :P
Old 08-01-2012, 10:18 PM   #246
islandhopper
OK, so i thought i'd try and clear a few things up for you...
Here you can see the D2S to Amp adapter connected to the HID ballast. The adapter plugs into the Amp connections and converts it to a D2S connector so you can use D2S bulbs.
The most common types of HID ballasts are 'Amp' and 'D2S'. Amp is common in aftermarket kits and D2S is common for OEM set ups. If your HID kit is not D2S, then it most likely has Amp connections.
My HID kit has Amp connections so i needed the adapter to power my D2S bulbs.
Here you can see the rear of the D2S bulb and the adapter that fits onto it. Notice the locking ring holding the bulb in place...
Since the projectors are D2S mini's, they will only accept D2S bulbs. 9006 bulbs WILL NOT WORK, unless you do some heavy modification...which i wouldn't recommend...at all.
Here i took the bulb out. Again, notice the locking ring on the end. That is part of the projector assembly and holds the bulb in place by screwing onto the back of the projectors itself.
Here is the bulb connected to the adapter. Remember the locking ring goes on first to secure the bulb properly. This is just to show how things are connected. you would insert and secure the bulb BEFORE connecting the adapter.
Here is a view of the rear of the D2S mini projector. The bulb goes in first, then the locking ring over the end of the bulb, then the D2S connector/adapter.
Here is everything back together. My JDM lights have rubber boots to keep out moisture, so i had to run all the wires thru them first before connecting the adapter.
Hopefully this gives you a better idea of how things will go for you. It's really very simple. TRS has made it that way. Most everything besides mounting the actual projectors is plug and play.
If you have any questions. Feel free to ask.
Old 08-02-2012, 08:03 PM   #247
Raf99
Shakes hand of Function>Form. Thanks. Too kind of you to post up pics of this and clear things up!! Seriously, thanks for going out of your way on this. & also confirms for me that I need to buy the following to finish my setup:
- DS2 compatible shrouds
- Adapter hardness (as seen in your pics)
- & DS2 bulbs
I bought my HID kits from someone on cb7tuner here, but I can't remember the brand for the life of me. I think they are DDM's, which look like this: (I'll verify this tomorrow and find out the specs of them (they are at the garage)
& of course the bulbs are 9006s which look like this:
Way different than the bulb type for a DS2 mini projector. But I'm so glad I know. I got one more question for ya if its ok. When purchasing/picking a shroud type, do I need to choose one compatible with the DS2 mini projector or is it more along the lines of being compatible with fitting in my headlight housing that I'm using?
Old 08-02-2012, 08:34 PM   #248
islandhopper
Shakes hand of Function>Form. Thanks. Too kind of you to post up pics of this and clear things up!! Seriously, thanks for going out of your way on this...
Hey no problem, bud. Im glad to help.
As for shroud choice, it's a combination of both factors that will decide what shrouds you choose. Technically, there are no shrouds that TRS sells that are made to fit the mini D2S projectors exactly. Almost all of them will need to be modified to fit flush on the projector and fit into the housings.
I used the mini-gatling shrouds since the diameter is right, but they are too deep to fit flush on the projector, so i had to cut reliefs on the shrouds. They also are small enough to fit into the bezels of the JDM lights without having to cut the bezels. Since the USDM lights do not have interior bezels your options should be better than mine.
Truthfully, any shroud will work with enough modification. You just have to pick the ones that you like the best and make them work. I have another set of 'iris' shrouds that i will be modifying and putting in soon.
So pick what you like and be ready to cut them up a little bit so they work.
Old 08-02-2012, 09:17 PM   #249
Smokinspeeds
Since its moderate modification to put hids into our headlights its not much to shave shrouds with a dremel. Just pick the shroud that looks best to you imo.
Old 08-06-2012, 04:27 PM   #250
1990[H]accordex
Location: Canada, Nova Scotia, Guysbrough/Truro (Second home)
1990[H]accordex is cool... so far.
any new updates?
1990[H]accordex is offline   Reply With Quote
Old 08-06-2012, 07:12 PM   #251
Raf99
Originally Posted by 1990[H]accordex View Post
any new updates?
of course there is.....
To follow up with the HIDs talk. I checked out my 3K yellow HID 9005 kit I had and they are Tenons. They have the following stats below, and I'll assume that the ballast (35W) can be used with the DS2 bulb type.
I haven't read up yet on the diff between a 35W and 55W.... BUT... just looked at the website and I can use my ballast with the D2S: Philips 85122+ bulbs:
Projectors
All (low beam & bi-xenons) designed for use with D2S bulbs
Ballasts
All (35w & 55w) models designed for use with D2S bulbs
OEM Applications
All that use D2S bulbs
Sooo all I need is bulbs ($95+tax/shipping), adapters ($15+tax/shipping), and shrouds ($40+tax/shipping). I'd like to buy some JDM housings too. So this project won't be done anytime soon, but its definitely in the works!
I decided my next big project (besides the HIDs) is to finish the rear disc conversion. I have most the parts except for the dust shields, pad clips, and a few bolts. The hardest challenge is trying to figure out how this all goes together exactly. Like the brake hose from the caliper to the upper connector, I'm not sure if it should be twisted like this, but I couldn't figure out any other way for it to go.... I'm going to check out other pictures I have and sort things out there.
And........ if you're still reading. I found a 92 accord LX in Sydney that has 76,000km on it. Yes, I said 76,000km. I am .... shocked. Going to try to get pics of this car, so far all I know is that it has one owner, an old lady.
Old 08-06-2012, 07:31 PM   #252
Raf99
Ya, after looking at pics I can see now that the brake line fitting goes the opposite way. Then the brake line runs over or under the hub and down the trailing arm.
Old 08-06-2012, 07:55 PM   #253
Smokinspeeds
I paid 10$ shipped from a us seller for my d2s sockets to fit my xentec brand hid setup and they arrived and look pretty good, with good cables on them. That's US obviously but still good.
Old 08-06-2012, 09:44 PM   #254
Raf99
You're saying you paid $10 for adapter wires to fit DS2s?
Old 08-06-2012, 09:51 PM   #255
islandhopper
The bulbs you're after can be had for much cheaper on eBay...
http://www.ebay.com/itm/Pair-New-OEM...f6048a&vxp=mtr
They are legit and this seller has an awesome rep on eBay and HIDPlanet.com for selling genuine bulbs with great customer service.
Old 08-07-2012, 07:55 AM   #256
Raf99
Thanks. I believe you told me this in a prior post, I was trying to find it last night. Should save $20+
Old 08-07-2012, 09:05 AM   #257
Smokinspeeds
http://www.ebay.com/itm/221085547272
These are what I got. About three days from pay till received. They look identical to functions sockets.
Old 08-07-2012, 05:30 PM   #258
Raf99
Appreciated! I'll def. order these up.
Old 08-11-2012, 06:19 PM   #259
Raf99
Thought I'd share some random photos from these beautiful days of sunshine we've been having. Truly one of the hottest summers we've had in a long time.
Old 08-12-2012, 12:13 PM   #260
crazymikey
crazymikey is very helpful crazymikey is very helpful
Nice. I've heard the east has been having nice weather. Ontario has been ridiculously hot.
Even out west here, we've had several weeks of constant 28-35c weather.
So glad the wagon has AC lol.
crazymikey is offline   Reply With Quote
