Old 05-20-2009, 11:10 PM   #1
ecudorian
ecudorian is cool... so far.
Question bent axle into motor mount..
I feel like an idiot because I got it recently.
Is there anyone that could fix it for a good price?
I can't find under $1300.
I hydroplaned and hit a curb, it bent the axle into the motor mount and messed up the suspension. It made me extremely sad. But if I cant get a better price, I may have to salvage it.
ecudorian is offline   Reply With Quote
Old 05-20-2009, 11:15 PM   #2
DriftMaster
DriftMaster may have said something they shouldn't have...
Send a message via MSN to DriftMaster
Do like I did when I totaled my rear end. Had about $900 damages, fixed it myself for around $200.
私は日本語を話さない
1990 Honda Civic DX - Junked
1992 Honda Accord Si - Sold for parts
Next Honda coming.
DriftMaster is offline   Reply With Quote
Old 05-21-2009, 10:28 AM   #3
batever
batever is cool... so far.
Do you have any body damage or is it just the driver's side axle and suspension parts?
If you post a picture of the damage it would help.
From your post I'm guessing you're not currently mechanically inclined, and without doing the work yourself, I would guess it's not going to cost less than your lowest quote. Still, ask yourself where can you find a good car for $1300? If you actually have the cash, repair may be your best option, unless you can find a well functioning car for less $$.
If you have the time and interest, you could fix it for less-much less.
A new axle (remanufactured) could run you $180, other suspension parts (depending on what it damaged) could run you $150-$250, $20 for fasteners, a Junkyard motor mount (assuming yours is damaged) I don't know, less than $50, and your time, and add on $80 for a professional alignement when you are done.
The more expensive and/or specialized tools (torque wrench, for example), or tie rod separator) could be borrowed from a place like Autozone.
Much less than $1300 in that case.
However, it's what most people who don't normally take their cars apart would consider a "big job" and you would have to read up and learn, maybe watch some videos on the internet to get a sense of what's involved for replacing each part.
batever is offline   Reply With Quote
Old 05-21-2009, 10:36 AM   #4
XcluziveAZN
XcluziveAZN is cool... so far.
damn you suffer more damage then i do
http://www.cb7tuner.com/vbb/showthread.php?t=135160
that me
Dude new Axle is 70 at advance auto part
Junk yard is your best friend. I'm going there soon for my car parts. Call junk yard around and see if they have what you need and bargain with them
I recommend you buy hayne manual. It will help you taking thing apart like i did
XcluziveAZN is offline   Reply With Quote
auto , bent axle , mechanic , work
