Go Back   CB7Tuner Forums > Beginner forum -- New members post here! > Beginner Audio/Electronics
Old 11-22-2012, 10:12 AM   #1
93cb7coupeSE
Newcomer
93cb7coupeSE is cool... so far.
Exclamation Remote start help Please!!!!
Hey guys i'm new here and I figured this is the place to go for help! This is my first remote start install and having some issues. I bought the viper 5101/python 1401 remote start and keyless entry system. Locks work great but when I activate remote start it flashes once, gauges light up I hear the viper unit click but then everything shuts off. Does this 2 more times and then re-locks the doors and shuts off. I'm having trouble finding out what wire goes where, Its the heavy gauge 8pin H3 connector
1-pink -- ignition 1 input/output
2-red/white -- + fused ignition 2/flex relay input
3-orange -- accessory
4-violet -- starter output
5-red -- + fused ignition 1 input
6-pink/white -- ignition 2/flex relay output
7-pink/black -- flex relay input if required
8-red/black -- + fused accessory/starter input
Currently I have the following wires connected on the ignition harness, if anyone knows please tell me what I did wrong, would be much appreciated!!! thanks!!
1-pink --- Black/Yellow
2-red/white --- White
3-orange --- White/Black
4-violet --- Black/White
5-red --- White
6-pink/white --- Yellow
7-pink/black --- None
8-red/black --- White/Black
93cb7coupeSE is offline   Reply With Quote
Old 11-22-2012, 02:14 PM   #2
lucifer1
CB7tuner Member
lucifer1 seems to have made some friends! lucifer1 seems to have made some friends!
The red/blk wire is a 12v input and needs to be connected to the white 12v feed. All red wires connect to 12v constant.
You also need to ground the blk/wht wire and connect the brake wire before it will work.
lucifer1 is offline   Reply With Quote
Old 11-22-2012, 07:31 PM   #3
93cb7coupeSE
Newcomer
So keep all my other wires where they are at, and run the rest of the red wires to constant power? I will try that.
Old 11-22-2012, 07:54 PM   #4
93cb7coupeSE
Newcomer
awesome!!!! it works great!!!! thank you thank you thank you!!!!
Old 11-30-2012, 11:21 PM   #5
Dynamic93-408
CB7tuner Member
Dynamic93-408 is cool... so far.
My bro just installed that on my cb and itits
Dynamic93-408 is offline   Reply With Quote
Old 11-30-2012, 11:22 PM   #6
Dynamic93-408
CB7tuner Member
My bro just installed that on my cb and its fing baller. Intergrated a kill switch to it if the alarm is not taken off the car will not start
Tags
diy , remote start , wiring diagram
