Old 07-28-2010, 03:15 AM   #1
fly68
CB7tuner Member
fly68 is cool... so far.
which f22 do I have?
I have a 92 Accord EX coup. For some reason I thought I had the f22ax engine. Which made me really happy because I want to get the bisimoto f22ax header.
Now I'm not so sure that I have that engine and I can't seem to find any info on what the stock engine in the 92 EX was. Someone please let me know. It's going to make a difference on the engine mods I make. Thanks, Fly.
fly68 is offline   Reply With Quote
Old 07-28-2010, 03:24 AM   #2
TypeG
Moderator
TypeG is very helpful TypeG is very helpful
the engine code is stamped on the block, below the header on the distributor side. later.
__________________
Avoiding dirt at all costs
TypeG is offline   Reply With Quote
Old 07-28-2010, 04:22 AM   #3
5spd92
CB7tuner Member
5spd92 is cool... so far.
Send a message via AIM to 5spd92 Send a message via MSN to 5spd92 Send a message via Yahoo to 5spd92
hmm considering its a EX coupe im assuming a F22A6, but to make sure check where TypeG said. As for that Bisimoto f22ax header the X in f22ax just means it fits any of the f22a's engine codes, like the f22a1, f22a4, and f22a6. since you have the stock F-series engine it will fit whatever engine code you have. hope that clears it up a bit.
__________________
Turbo Setup: 100%
5spd92 is offline   Reply With Quote
Old 07-28-2010, 08:25 AM   #4
deevergote
Don't call me dude.
deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool...
Send a message via AIM to deevergote
The "x" doesn't stand for anything specific. It's merely used to indicate any of the F22A engines... primarily the US models F22A1/4/6. If something says it's for "F22Ax", that means it is for every F22A engine.
You have a 92 EX, so unless your engine was swapped, it's an F22A6.
deevergote is offline   Reply With Quote
Old 07-28-2010, 10:22 AM   #5
Vex
Contributing Member
Vex may have said something they shouldn't have...
Send a message via MSN to Vex
Quote:
Like typeG said. X2
Mines an F22A4.
Vex is offline   Reply With Quote
Tags
engine , engine build , technical
