DunKrS : 1991 Accord EX
    DunKrS' '91 Accord EX 4 DR
    Engine:
    Original F22A4 and 5 speed manual 212,XXX Replaced at 209k with a super clean 60k F22a1 with a4 header
    2 1/4 crush bent from cat back, 16in glass pack into a magnaflow turbo muffler
    Ebay CAI with K&N 4" cone
    H23/a6 hybrid manifold with OBDII H22 throttle body (read Huge)
    Denso Plug Wires & NGK plugs
    Exterior:
    105 stickers (my birthday 10/5/91, I was born same year as my EX!)
    6k superwhite drop in HIDs
    Clear Corner lights
    Legend Sedan Lip
    Rear mud flaps
    sunroof visor
    Fogs with 88-89 prelude yellow caps
    Legit Gsquare Grill
    Interior:
    Completely stripped and cleaned interior
    Fog Harnesses A B and C and Switch
    For more pics and info on my progress thus far, check the link below out
    http://www.cb7tuner.com/vbb/showthread.php?t=165495
    Suspension/Wheels/Brakes:
    Koni Yellows Page 2
    H&R Race springs on ground control sleeves
    Neuspeed 4 point strut bar
    Megan Rear strut bar
    Rear Vigor Sway bar
    '00 Accord SE Wheels Gone!
    17" Racing Hart D6000's on 215/45/r17 Kumho Ecsta 4x
    '99 Acura CL Type S 11.1inch Calipers, brackets, and rotors
    93 EX rear disk brake conversion
    Audio/Electronics:
    Pioneer 6x9's rear
    Kenwood 6's front
    Alpine deck
    Kenwood 1000Watt Amp and MTX 12" sub
    OEM Keyless entry and Alarm
    Future Plans:
    Amber Corners Not sure I like the clears, may still do this
    JDM side markers
    Blackhouse headlights
    Super Super Future Plans:
    Rebuild my spare F22, Bisi Stage 2 Cam, H23 Intake, Bisi pistons.
    Orrr Boost for 7-9PSI ultra reliable, low maintenance, fuel economy when I need it, fun when I don't.
    Haven't decided which road I wanna go down yet though
    mmm...them wheels looks good on cb!!
      Thanks! I lucked out, got the set for $80 And the tires were $125 for the set less than 2000 miles on them! I plan on using your 90-91 grill DIY! Great writeup! Thanks for looking =)
        damn! that's a great deal!
          When I first got the old girl, got her for $1000. The timing belt was two teeth off, exhaust had huge holes it in (read: LOUD!), she'd been sitting in the bushes under a tree collecting dust and sap for 2 years, and her owner was killed in a motorcycle crash =((
          brought her home, cleaned her up, ran into a few issues here and there
          New alternator, exhaust, coil, ignitor, plugs, wires, battery, fixed timing belt issue.
          Later I replaced water pump, timing belt, timing covers (they were left off and thrown away...) and all gaskets on the drivers side of engine (no more leaks!)
          we're at 205,xxx and she's still running great for me! Freeway trips are a breeze!
          Still not getting very good mileage, maybe time for a new O2 sensor and an ignition tune up!
            Those rims look real good man!!!
            My coupe!!!
            Originally posted by Racer_XXX
              Thanks! =)) I want some less-low profile tires eventually but for $125, I couldn't complain
                nice ride man wheels look good very clean
                bought from:CBsevenTUNER
                  Thanks guys =)
                    Looking clean.. Keep it up
                    Accord Of The Month January 09
                    Accord Of The Year 09
                    My 2 Babys
                    BMW TECH FOR 15 YEARS
                      great sedan man .
                      A man that keeps looking back can't see whats in front of him.
                        Update! Lowered the front on Skunk2 coil sleeves and Tokico HP's
                          Looking better... now lower it a bit more.
                          Checkout my MR: http://www.cb7tuner.com/vbb/showthread.php?t=165984
                            Yikesss, Idk if I wanna go much lower except to bring the rear end down a little to match, I scraped all over town as it was (I'm used to driving my dodge with 9 inches of lift and 37's ). Idk what happened but my front left brake rotor wasn't letting go, I took the pads and caliper bracket off to check the condition of the front brake pads and rotor but I put everything back the way she was before. Haven't driven it since that night just to be safe. Gonna give the brakes and all the nuts and bolts associated with the lowering job a once over tomorrow to make sure everything's tight after work and bleed the front ones to get the old dirty fluid out anyways, then I'll have fresh fluid throughout and I'll feel good knowing I didn't forget anything. I'm in dire need of new front rotors soon though so I wasn't sad about the rotor being cooked.
                              Note the DIY/temporary Electrical Tape Eyelid Hellaaaa JDM!
