okay, first off, today i spent the whole day replacing all four engine mounts and cleaning the egr ports. i had to disassemble the fuel injection system, and many vacuum lines and connections. i had to disconnect a heater hose and lost quite a bit of coolant. but i did replace the coolant and bled the system. i had to drive an hour home and immediately the car starting overheating. i turned the heat on full blast which brought the temp down to a level i felt safe driving. on the highway it overheated more, and i pulled over several times. i popped the hood whenever i pulled over, and with the engine on NONE of my fans were blowing. when i turned the car off, one fan turned on. i checked the fuses and relays for the fans and they were good. i am almost positive i got all the connections right. maybe a vacuum line got crossed, but that really shouldn't cause overheating. shouldn't at least one fan be on while the car is driving on the highway, especially if the car is overheating? i am going to check again in the morning with more light, but any suggestions will be greatly appreciated.
thank you.
thank you.
