I have a little free time tonight, so I thought I'd finally start my F22A build thread. I've done research and gathered parts for about a year (I don't have a lot of free time). I finally took the head off a couple weeks ago and took it to Pure Tuning in Toledo, OH. So, I'm finally going.
I'll just list my plans in this post, to keep things organized. Build will include:
- F22A head, rebuilt by Pure Tuning, plus some basic exhaust porting and 0.030" head mill
- Webcams.com camshaft: 0.400" lift (I/E), 202/199 deg duration (I/E) @ 0.050" lift, 114 deg lobe separation
- Bisimoto valve springs
- Bisimoto adjustable cam gear
- H23 intake manifold, including IAB
- H22 throttle body
- Prelude Si air filter box and connecting tube
- Bisimoto F22A header (I sure hope it doesn't leak)
- 2.5" OBD2 Magnaflow catalyst, 2.5" exhaust & resonator, Integra Type R muffler (2.25") - I don't want a lot of noise.
- H22A fuel injectors, cleaned and balanced by Mr. Gasket
- P72 ECU, chipped with Hondata S100 - will be tuned by Pure Tuning
- Windage tray (std. on my F22B1 block)
- Quaife LSD
- Koni Yellow Sport struts
- Progress rear sway bar
While I'm at it, I am replacing timing belt, water pump, rings, rod bearings, all water hoses, and most gaskets.
I know I'm not going to wind up with as much power as I would with an H22 swap. I decided against that for two reasons. First, I did an H22 swap about 10 years ago. Despite a "guarantee" that the engine had less than 35k miles on it, it only lasted about 20k before the compression went. If I'm going to go to all this trouble, I want an engine that will last for a while. The second reason is that its kind of cool to see what I can get out of the F22A.
- H22 throttle body
- Quaife LSD
