F22a4 Block.. ok to use?
    ok my block in my car is bad and i have this block to use well just wondering your opinion on what you think of it.. is it ok to use?
    cylinder 1
    cylinder 2
    cylinder 3
    cylinder 4
    No one can tell from the pics, If the cylinder walls are clean and no scratches then the block may be ok. But you will have to put a head on there atleast and get a compression test.
      you might as well rebuild it while its out. I understand ur block is bad and u probably need the car back and runnin but if u rebuild in real quick then you'll know it will be good when u start it up and you will get atleast another 200,000 miles out of it lol
        ok well herers pics of the cylinder walls (not in order or anything)
          no one?
          bump/\
            This looks like a high mileage motor that's had the cylinder head off for a bit. Your best bet is to put on a new head gasket, known good head and do a leakdown test on it.
            Personally I wouldn't use it. My guess is that it has over 100k on it.
            Jei Chang
            BlackTrax Performance
              leakdown is the only way to go, it will also let you know if the valve job is any good on the head as well.
              I <3 G60.
                are you going to rebuild it or are you just going to slap the cilinder head in there and go on with ur business??????
                the engine looks ok. you gonna have to clean the shit out of the top before you put the head on.......
                my suggestion to you it would be to rebuild it.......
                its not hard. just get a manual and follow the steps and you should be good.
                are we there yet are we there yet are we there yet
                  looks like you need to do some cleaning work. hone the walls. and put new piston rings in. also change the seals, water pump and timing belt. and your set.
                  miss my turbo cb7
                  moved onto volvos. dont know how that happened, just did
                    yea i understand what you guys are saying with the rebuild but i also dont have the extra cash. Is there a cheaper way to do this or should i just tryin putin it all together and see how it runs.
                    Also i put my new head on my bad block well it still smoked well i just got done pullin the head off and heres the block revealing my problem.
                      Green! That doesn't look right to me.
                      ...cuz i got the hots for timmy0tool 1992 Accord EX
                        no def. not lol
                        bump
                          heheha I'm a noob at this stuffs.
                            ok ppl im sitting here banging my head on the wall plz let me know what i can do..
                              omg im gonna start crying
                              might as well push my cb off a cliff
