Welcome!
PICTURES ON EVERYPAGE!!!
Best Viewed on a 19" Monitor with 1280 x 1024
Dial-up ppl, u've been warned
ENGINE & DRIVETRAIN:
-1993 Honda Ascot 2.0Si DOHC F20A
-1993 Honda Ascot 2.0Si 5-Speed transmission H2J4
-150 hp @ 6100 RPM
-137 ft-lbs @ 5000 RPM
-6700rpm redline
-Compression 9.5:1
-Bore: 85mm
-Stroke: 88mm
-Honda Gasket set
-Custom 19T Waterpump
-Cruise Control Deleted
-A/C deleted...well not really...its broken
-DC sports 4-2-1 header
-Magnaflow Catalytic converter
-RS*R Exmag Stainless Steel Satin Black Cat-back Exhaust
-Prelude Starter motor
-200Amp high current Alternator
-DA Integra Airbox with 3-way intake tubing, Crown Vic Venturi Tube
-short throw stock height shifter from yeamans17 :: crazy mod! recommended
-Battery Trunk Relocation
-New HONDA OEM drive shafts
-AC removed (almost, it hasn't worked for 4 years)
-new VSS and drive unit :: there is a weird ticking and the old drive gear was warn down??
-UBER DUPER valve adjustment Oct 2008:: extra torque and lower NVH
-new coolant lines
-new soft power steering line :: does the job
-exhaust gasket set
-New Honda OEM VSS
-New Honda OEM VSS drive gear
EXTERIOR:
-Redone 90-91 Accord Color: Cappuccino Brown Metallic Clearcoat YR-501
-1995 Acura Legend Sedan Front Lower Lip
-1993 CB9 front bumper
-1991 CB Japanese 1-pc headligts
-1993 CB9 amber turn signals
-1993 CB9 fog lights :: wired
-2.0Si badge
-Satin black accents & badges
-new windshield ::windy day + open hood = cracked
-new Original Honda Hood
-Junk Yard quarter panels
-Lexus rear projector fog light :: check. now I need to install it.
-Honda OEM mud guards
-CB3 Chrome front Grill
-CB3 brown tint windows ::driver side installed, 3 more to go.
INTERIOR:
-Original Honda Accord Light Beige Mouse-fur seats
-Brown Dash & Highlights (EX model)
-New Shift Boot!
-CB9 Fog light switch :: check...too lazy to install
-CB9 Half Antennae switch :: check...no antennae to install
-Tan Color 6.5" Rear Speaker Pods
-new used Black Plastic dash
-Broken Speedometer :: check...too lazy to fix
-1st Gen ITR steering wheel :: great upgrade....highly recommended, now I need to setup the horn.
-1991 Toyota AE92 Red Sports Seats ::installed, needs a cleaning
-Astrovannin custom seat brackets :: Thanks Dustin!
-new driver door control module :: my mirrors don't go crazy anymore
-1993 CB glove box damper
-1993 CB tan sun visors ::looking for ones with lights
SUSPENSION/WHEELS:
-Ol'school Racing Hart D/Spec Superlative Racing Dish 16x7.5 with 35mm offset
-Bridgestone Potenza G009's 205/50-16 gummies
-Replacement Honda Ball joints and control arms
-Tein H-Tech Springs
-Tokico Blue, HP shocks
-Goodridge Stainless Steel Brake lines (a really good modification for any CB)
-Honda Rear Drum Assembly
-STracing Sway bars :: need to powdercoat them b4 install
-Poor-man's Big Brake Setup :: kiss the windshield::
-1994 Acura Vigor 11.1" front rotors
-1994 Acura Vigor Honda Remanufactured Caliper Assemblies
-1994 Acura Vigor Honda OEM Brake Pads
AUDIO/ELECTRONICS:
-Security....undisclosed military-style security system.
-Clarion Mp3 deck (will get model number)
-Clarion Pro Audio 6 1/2" components up front
-PPA 6 1/2" Mid Woofers with Planet Audio Crossover & Tweeters
-15dB Radio Antenna Amplifier
-Kenwood 800W 4-Channel Amp ***love it, don't need a sub anymore***
FUTURE PLANS:
-12" Kicker Comp C12 sub
-Pioneer GM-3300T 2 Channel Amp :: picking up tomorrow.
-Honda Ascot Instrument Cluster
-Honda Ascot 2.0Si Prestige emblem
-Honda Ascor 2.0Si F20A DOHC Variable Valve timing unit
-PT2 ECU
-engine wash & detail
-paint valve cover
-Honda replacement antenna
-roll rear fenders
-fog light HID's
-Rear disk swap
-Hondata engine management
-suspension overhaul
-LED bulb transplant
NOW
