86 mm bore
.827 wrist pin diameter
1.181 compression height
the bore fits, the compression height is a wee shorter, my stock piston measured out to 1.217" but my rod is 1.5mm taller.
im going to have to order an extra set of prelude/accord wrist pins so that i can bore the K20 piston wrist pin out (stock is .869)
Mahle 12:5.1 here i come! after i do a little bit of research and make sure it fits with no problems
oh with vertical gas ports too
