swapping in an F22A6 cam and PT6. explain this!!!
    Yeah thanks for all the help by everyone. Hope I can get it out in one piece and they don't try to charge me for every little piece.
    MY MEMBERS RIDE THREAD
      Every IAB equipped CB that I've ever seen, regardless of year, is always on the bottom of the runners. That also includes preludes too, at least 92-96. I'm not sure about 97+ preludes, I'm sure the same would apply. Having the IAB black box on the firewall does not sound stock at all.
      OP-if the car's completely in the dirt, it is possible to pull the whole IM off from the top. The hardest bolt to get to from the top is the bolt for the diagonal brace that goes into the runners @ the bottom. Could be faster than trying to safely get it up in the air to work underneath it While you're in the yard, def. look for h22 and h23 preludes, those would donate the much better plenum + t/b too.
        if the car is in the dirt, just dissasemble the upper manifold. That gives you enough room to get to the bottom brace.
        Man I remember being the first one to actually document the stuff for the a6 swap. Crazy.
        Retro!
        Hater
          You should prob get the brace too as it is a little bit longer than the one for the A1.
          I know plenty on people on here just run it without it when they swap but I feel safer with it on.
          Also if get the black box and the actuator is broken like mine was you can pick them up from quite a few diff places. If you have a short ram intake when you disconnect the stock airbox use that one. Just unscrew it and replace it on the black box.
          steve
            ^good info, I always assumed the a1/a4 brace would be the same. It is def. a good idea to run it, IIRC steelbluesleeper (sp?) cracked runners 2 or 3 times w/o the brace, not fun.
