nice rides. is250 or 350?
Blk EX Coupe : 1998 Lexus SC300
how hard was that to do? i've been thinking about getting one of those led kits that comes with replacement lights for just about everything.
http://www.luxurymods.com/superwhite...0sc300400.aspx
Originally posted by Durrby View Posthow hard was that to do? i've been thinking about getting one of those led kits that comes with replacement lights for just about everything.
The shifter is the most complicated out of all of them. I actually cracked my shifter during the process of removing it.
Basically you just need a flat head and phillips screw driver to remove everything, so it is pretty straight forward.
You'll need the following for the interior:
1 - Festoon bulb - Center dome light when door opens
5 - #74 LEDs - Driver footwell, ignition key ring, cigarette lighter, shifter, glove box
2 - BA9 - map lights in the center
3 - 194 - 2 for door lights and 1 for the trunk
Outside you'll need
6 - 194 - for the rear license plate right, 2 for front bumper sidemarkers, 2 for headlight markers
I paid a bit more than that kit because I'm using Polarg B1 Hybrid interior lights instead of LED, but I think if you buy LEDs on ebay it could be had for cheaper. If I was going to do it again I'd probably get one of those SMD circuit boards that Tony (luxurymods) sells for the trunk and center dome light. http://www.luxurymods.com/universalledboard.aspx
Thanks for the info. I may try this in the future but I swear everything I touch car wise, breaks. haha
Primarily I just wanna find an led to match my 6000k low beam hids. It just looks off having the blueish/white hids and the stock halogen bulbs in my parking or city lights, whatever there called.
I was looking at these but on another site it mentioned to not use these types of bulbs in the headlight housing because the heat may cause led failure. So i've been hesitant on buying them.
http://www.v-leds.com/Exterior-LED/C...81039-1-2.htmlLast edited by Durrby; 02-01-2010, 12:04 AM.
Originally posted by Durrby View PostThanks for the info. I may try this in the future but I swear everything I touch car wise, breaks. haha
I'm using Polargs to sort of match with my TSX retrofit. It isn't perfect, but its better than stock.
I bet those things tickle you in just the right spot.
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
Not sure if you're on clublexus, but i thought these were some good ideas for tail lights...
http://clublexus.com/forums/sc-400-3...tails-diy.html
And ive always liked the Red/Clears for these bad boys...
