Where can I snake the 0 gauge into the car?!
    I had a 4 gauge kit but upgraded...and now i cant seem to put through the 0 gauge wiring through the passenger firewall. Can anyone suggest any other 'sweet spots'?
    Left Hand Drive or Right Hand Drive? On my RHD when I put my 2 gauge through a hole just beside the throttle cable and under the fusebox, and fitted a thicker rubber grommet for extra protection. Maybe LHD the same? Other wise, you could always make a new hole and go through that
    My 5.7 LS1 Holden Ute
      when i install, i drill a hole through the clutch plate.
      what makes you think that you need something bigger than 4 guage?
      how many amps, whats the fuse ratings on each amp?
      Retro!
      Hater
        Just drill a hole.
        I cant Slam further. The ground refuses to get any lower.
          at least 1400 watts rms for both bass and speaker amp......so i want to feed them the 0....i tried so long yesterday with my buddy, but will prolly just drill a hole
            0 gauge could run a small business
              I'm running my 0 gauge AND 4 gauge wire through the passenger side of the firewall. There is a small grommet above the carpeting over the passenger side foot area.
                whats the fuse ratings on teh amps....thats what will tell you what guage wire you will need.
                Retro!
                Hater
                  x2 I've got a 6 gauge wire, oil pressure line, and something else I think running through that grommet. With plenty room for more.
                  Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
                    I ran my 2 through a grommet on the passenger side near the heater core. Peace
                    Keep an Eye on my Coupe. Click the Pic
                      Just ran my 4 gauge through it the other day. Go to the passenger side, lift up the carpet and there will be a grommet above the computer. Plenty of room, I cut a hole in the grommet so it would be snug.
                        k im gonna give it a shot....if any one has any pics it would be greatly appreciated....
                          its really not that hard, just pull back the carpet, and you'll see it already cut out with a black rubber plug.
                            on my 93 ex there is a plastic plug on the passenger side that just pops right out. Just pull back the carpet a little and you should see it, it popped out pretty easily to.
                              Seriously, from an electrical standpoint unless you're pulling 100+AMPs, 0-gauge is not necessary at all.
