I've just replaced my cap and rotor, fuel filter. Test drive and it's bogging (around 1500) and almost die. And it's throwing code 43 now. Any idea to fix it? My oxyen sensor I just replace it a month ago? Thanks
Tume up aftermath.
----------------My 92 Honda Accord LX---------------------- My 97 Nissan 240sx LE----
NE GUYS, Buy the last of my accord parts
spark plug wire
Can some one post your spark plugs wire from the dizzy to the sparkplug holes? So I can compare with mine to make sure they are the right orientation. I search but I did not find any pic. One more thing it's idled fine. However when I drive it it's just bogging down and almost die. Thanks
Originally posted by 93SECan some one post your spark plugs wire from the dizzy to the sparkplug holes? So I can compare with mine to make sure they are the right orientation. I search but I did not find any pic. One more thing it's idled fine. However when I drive it it's just bogging down and almost die. Thanks
SEARCH is your friend
it has a killer pic on that thread
http://www.cb7tuner.com/vbb/showthre...t=firing+order
The code is for fuel supply system. My guess is you kinked a line or didn't remove one of the little plastic caps on the new fuel filter.Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
Originally posted by OttoThe code is for fuel supply system. My guess is you kinked a line or didn't remove one of the little plastic caps on the new fuel filter.
Originally posted by xfactortype1stupid idea but did you tighten it properly. i mean the banjo bolt. might be the washers to the fuel filter. some folks report leaks with aftermarket washers
I dunno i just seafoamed my car. I took out my o2 sensor and put in a bad one so not to fuckup my good one.
After 5 minutes of hard driving, a CEL came on. o2 sensor and Fuel supply system. Changed my o2 sensor back and cleared he ECU, it never came back
Originally posted by JohnD1079I dunno i just seafoamed my car. I took out my o2 sensor and put in a bad one so not to fuckup my good one.
