I just bought this car and love everything about it! Except for the auto transmission.
First off it slips pretty bad in 2nd and 3rd. It slips to the point of gunning it and seeing the rpm's reach like 2000 before even moving. I read more about the fluids used and am going to try the Honda ATF-Z1 from the dealer and hope that will fix some of the slipping issues.
The second thing really baffles the he!! out of me....depending on temperature of the day it seems, the trans will only use either 1st and 2nd or 2nd and 3rd. If in the D4 position it will stay in 2nd or 3rd depending what it wants to use at the moment. D3 will use 2nd or 3rd also, 2 will use 2nd, 1 will use 1st or 2nd. It will shift from gear to gear, but will only use 2 out of the 4 at one time....I don't think it has used 3 gears at all and I am almost sure it hasn't used the 4th gear or the OD. Could it be the shift soleniod?
Also, the "S" light is always on reguardless of swith position on the shifter handle.
Also there is a slight dip in power like it boggs badly at about 1500-2000 rpm, could that be clogged EGR passages?
Another thing is the speedo zero's out while driving. I could be going 70 and the speedo just goes to 0 and like a minute later it seems it will go back to normal.
The car is a '90 Accord LX coupe with a F22A1 Auto transmission and 153xxx miles on it. The trans fluid level is correct, but not sure about the fluid type in there at the moment...I think it is Dextron III.
I know this is alot to ask about, but the car is intended as a daily driver. So, I need to fix these things as best I can. I do plan a H22A with a 5 speed swap, but it will be later down the road.
Thanks for any info you can give me on these problems.
The attachments are pics of the car.
