The "S" light flashing...
    Ok, I've a 91 accord, it's automatic. The "S" (sports) light on the panel starts flashing when the car warms up (like 5 min after I turned on the car). When it's running, the tranny changes from 1 to 2nd abruptly, sometimes it don't wanna grab the 2nd and from 2nd to 3rd always it feels like slips a lil bit (accelerates like on neutral gear 1 or 2 secs) . I recently changed both solenoids and I was thinking to make a transmission fluid change to fix the gear problem, but I dont know really what the flashing "S" means and how could i fix those problems. Please help, thanks.
    The flashing S light indicates an error code in the TCU (transmission computer).
      http://www.cb7tuner.com/vbb/showthre...t=check+engine
      this will make the s light blink in a specific order of codes
      TCU Codes:
      CODE LIST:
      1-Lock-up solenoid 'A' circuit open or shorted.
      2-Lock-up solenoid 'B' circuit open or shorted.
      3-Throttle Position Sensor circuit open or shorted.
      4-Vehicle Speed Sensor open or shorted - No signal from speedometer.
      5-Shift Lever Position Switch circuit shorted.
      6-Shift Lever Position Switch circuit open.
      7-Shift Solenoid 'A' circuit open or shorted.
      8-Shift Solenoid 'B' circuit open or shorted.
      9-Counter shaft or transmission speed pulse generator open or shorted.
      10-Coolant Temperature Sensor open or shorted.
      11-Engine RPM (Ignition coil signal) open or shorted.
      12-(No code 12 used)
      13-Main shaft speed pulse generator open or shorted.
      14-Linear (line pressure control) solenoid open or shorted.
      15-Kick down switch circuit shorted.
        i was told that to fix the flashing lights was to change the trans computer
          If your TCU was bad then yes this would fix his problem. He needs to figure out what code it is first before pulling the TCU out. Once he has that information then he can properly diagnose the problem. dakiid listed the proceedure and the list of trouble codes.
