Tachometer Wire
    Tachometer Wire
    Trying to locate the wire for the tach output...
    does anybody have any clues? I can tap from under the dashboard or the engine bay..but which color wires and what tap in the engine bay do i have to make?
    Running on a carb so the ignitor is built into the distributor.
    do u have a service manual?
    Retro!
    Hater
      does anyone know where the tach wire is in the fuse box? I need to know as well.
        on 90-93 accords the tachometer wire is blue. if u remove the dist cap you will see the solid blue wire. thats the tach wire. splice into that if your trying to hook up an after market tach.
          Is there a wire under the dash? I don't want to go into the engine bay if I don't have to.
            lol its a lot easier to remove 3 screws on the dist cap to remove the dash. its very easy to find. but yeah if you have dash apart the wire remains blue. it might be a bith finding it but its there. the tach wire is solid blue. i think u should just splice into the wire under dist cap. its a lot easier.just remember the spark plug wire order.
              i'll just splice into the distributor then. thanks
                I agree, that is the easiest thing to do.
                Honda-Tech Username: Lostcb7
                The cb7tuner.com OG.
