FYI: Sprint Spring rates inside!!!...
    F/R in #/in: 265/175, or ~4.6/3.4 kg/mm, so it's right in the league of all those super-drop JDM springs (Tein S. Tech, Tanabe DF210), etc. We should get a list of all the rates like they have for Civics.
    Originally posted by lordoja
    yes we should! delete ur post and make a list! i got some spring rates to help out the list
    Arospeed Coilover.... Front 500lbs/in Rear 400lbs/in
    DropZone Coilover.... Front 450lbs/in Rear 350lbs/in
    Skunk2 Coilovers.... ?Front 500lbs/in Rear 400lbs/in?
    Tein Basic/SS/CS.... Front 336lbs/in Rear 280lbs/in
    Tein S-Tech.... Front 246lbs/in Rear 162lbs/in
    Tein H-Tech.... Front 224lbs/in Rear 151lbs/in
      My skunkworks (skunk2) coilovers are 560F 560R (10kg/mm)
      91 4DR Accord LX White Auto
      Generic Mugen Lip
      Generic Intake
      EX 4-2-1 Header
      Dynomax Muffler
      Skunk2 Coilovers 560lb/in and Koni Yellows
      ST Rear Sway Bar
      17" Eagle Alloys/Kumho 711's
        What sprint spring rate you talking about, the 90-93 accord #1003 that drop 2.25 or the 90-93 #x1003 that drops 3.25?????? Or they both the same.
          my dropzone coilovers are 650 front and rear and i like the way the ride
          cb7 sold
          2002 mineral gray mustang gt not stock
          95 accord lx daily driver
            Here's some more:
            Neuspeed Sport:260 lb/in up front and 165 lb/in for the rear, 1.75"/1.5" drop
            Neuspeed Race:485 lb/in up front and 300 lb/in in the rear, 2.25" drop?
            Tein S-Tech: Front 246lbs/in Rear 162lbs/in, 2.1"/1.7" drop
            Suspension Techniques Speedtech:250lb/in linear/180lb/in progressive, 2.0"/1.8" drop.
            Keep 'em coming people...I think Tanabe's DF210s are basically the same as the S-Techs; all that's left now really are Eibachs and H&R's. I have a book that has some formulas on springs, so if anyone has any springs laying around that they can get some measurements on, I can see what happens when you cut them from an engineering standpoint. I know springs weren't designed to be cut, but honestly, one coil is not going to drop the car dramatically, make the spring bind immediately or raise the spring rate to unrideable levels. I'll put some forumlas up later.
              question for you ..............how low is your car? are those wheels 18s? clean as hell, my style yea this is as hell
                Just some quick info for you all ,if you are unhappy with your tein spring rates(I was) then you can order your coilovers with prelude springs. about 50 to 100 lbs. stiffer.
                FS: BNIB MFactory FD $650, PM me.
                  Bump, important info here...
