CAR WILL NOT START ( RPM/SPEEDO DROPPED to "0" while driving )
    ok...im driving...and the damn RPM gauge and the SPEEDOMETER drops..to BOTH "0" I turn the corner...and the car shuts off....I tried starting it...and NOTHING...when you turn the key to "ON" ...NO DASH INDICATORS....NOTHING COMES ON like its suppose to....
    what the hell is up with it?????
    could it be a fautly ECU..or what??? this is the FIRST I had to encounter something like this
    NOTE:
    everything WORKS...lights...stereo...EVERYTHING...but the DASH INDICATORS ( CEL...OIL...BATTERY..) those WILL NOT COME ON...now when you turn the key back to "OFF" the "red" indicators flick for 1/100 of a sec..
    ( Battery...OIL.etc )
    when you turn the key....to "ON" the CEL...OIL...BATTERY..ETC is suppose to come on..BEFORE you start...well..NOTHING is coming on..
    and it cranks..but WILL NOT START....
    HEEEELLLLPPPPP!!!!!
    SHADOW1 .....if you read this....
    IM NOT SELLING IT.....it won't start...im being honest...I don't want you to buy a car that has some sort of ELECTRICAL mishap...
    sorry mayne!
    92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
    MR Thread:
    http://www.cb7tuner.com/vbb/showthread.php?t=174586
    My tribute page: http://www.cb7tuner.com/vbb/showthread.php?t=70489
    my car did this i kicked the fuse box and it quit acting up lol i think its the alternator
    To have loved and lost is better than to have never loved at all #CB7Life
      the alternator will cause the RPM and the SPEEDO to drop to 0 and cause the dash indicators NOT to work and cause it not to start???????
      are you serious Soy..mayne..how much them shits cost???
      MR Thread:
        Mine had basically the same symptoms...It was sumthin fucked up in the distributor...The re-ingnition ignitor.
        Edit...I see you have a sale pending with the car...Just to let ya know that if you have the same thing as me...It was a really easy fix...decently cheap too.
        Burrito Bandidos: It will change your fuckin life
          same symptoms?? and it was inside the dizzy that caused the RPM & SPEEDO dropping down to 0 while driving, dash indicators not working... as well as NOT STARTING...
          hmm...personally...I think its something with the wiring ( alternator )..thats just my guess!
          BUT I do appreciate your input...its GREATLY taken into consideration...I just need my CB to start and run...I need it to get to work! :sad:
          MR Thread:
            I thought the same thing....I didnt question it tho when it started workin again.
              iunno i wouldnt replace it right away. i say if the car doesnt start. pull the main relay and check the solder. then if thats ok i would come back here and post lol
                this shyt happend to me 2 it stop all the suddent it's happend to me like 2 times allready the car still ingnites but doesnt start any suggestions?
                  which main relay???? under the dash on the driver's side???....I saw a silver box that wasn't bolted down...and it said..( Main relay )..with something like 12 or so Volts...im not sure...it was like 1am...and I had a shitty flashlight....LMAO
                  which main relay am I looking for Soy???????
                  and then I walked through the wiring....theres a small box on the driver side in the middle ( cruise control and strut ) UNDER THE HOOD..I think thats my Fuel Injection relay...but theres a ( Orange wire ) thats going into the harness plug...its got a pinhole in it...and I can see some copper
                  MR Thread:
                    I was going to say igniter as well, but I recall when my car stopped on me a few years back, all my indicator/dash lights did work. Other symptoms were the same.
                    '92 Accord LX Sedan--Bordeaux Red Pearl --OEM--279k Daily Driver
                    EX Lip & Alpine OEM single CD Player. No more useless pocket!
                      yeah bro its the grey box under the dash. its bolted on with 2 bolts. and you got to remove a box to get to it. when my ignotor went out the RPM didnt work but everything else was fine soo im guessing its not that. but if your car doesnt start check this relay. then well work from there. like i said my gauges were acting up just like yours, and i checked the amount ofliquid in my battery and its low, so im a change my battery and see whats up!
                        how would the igniter affect the dash indicator lights?
                        its not starting...I checked all the grounds..and they're good!
                        MR Thread:
                          its the GREY box thats under the driver side dash....mine wasn't bolted on....its just HANGING..."Literally" no bolts holding it onto anything!
                          you think from it hanging .....shorted out something????
                          MR Thread:
                            IM thinking....MAYBE...the MAIN RELAY under the dash was suppose to GROUND itself when bolted..
                            IM thinking....from it not being bolted....shorted something out
                            MR Thread:
                              wierd um disconnect it, then pop the grey cover off and check the solder leads.
