issues with check engine light
    i did some quick research, cant do much cause im going to work in a bit and found a few things on the tcu diagnosis...but it seems to be for the 93's cause they have no s light
    i guess my dad was driving and the s light started to blink and then check engine light came on.
    i read the codes and the check engine light blinked 6 times fast...i think its coolant temp sensor or somthing. but then the s light would blink one time constantly...it would be like "blink..........blink...........blink"
    does anyone know the tcu codes...ill search more later but i need to know soon cause we just purchased this accord and it has a new tranny.
    thanks.
    Retro!
    Hater
    http://www.cb7tuner.com/vbb/showthre...t=tcu%2A+codes
    1. Lock-up solenoid 'A' circuit open or shorted.
    its not hard to check the solenoids, its just apply battery voltage and the solenoid will click.
      i tried the 12 volt to the silinoids and they didnt click, so i put another one in i got at the junkyard and tried to put 12 volts to it and it didnt work...i put it in anyway and its all better.
      thanks.
      Retro!
      Hater
