Engine
Euro-R H22 (2000)
Euro-R T2W4 LSD Transmission
Kaizen manual timing belt tensioner
AEM V2 Intake with a Blox 4" Velocity Stack (powdercoated wrinkle black)
k&N Air Filter
Euro r Intake Manifold(Rosko Racing Package) Plenum ported to 68mm
Professional products 68mm throttle-body
Hondata Intake Manifold Heat Shield Gasket
Aem Fuel Rail
Aem adjustable Fuel Pressure regulator
Fuel pressure gauge
NGK Platinum Spark plugs
NGK spark plug Wires
Highend tri-y Header with 2.5" collector
Chipped p06 converted to P28
Apexi World Sport II Cat-Back Exhaust (deleted resonator and cat)
Eliminated A/C ,Cruise Control, and powersteering(looped at the rack)
Innovative Motor Mounts
Forbidden Short Shifter (with prelude shifter plate)
CorSport shifter bushings
Odyssey Mini battery
Koyo Aluminum Radiator
S2000 Clutch Master Cylinder
Rywire Clutch Line (goes direct from slave to master cylinder)
Mildly wire tucked engine bay
ACT 6 Puck Clutch with Heavy Duty Pressure Plate
ACT Pro-Lite Flywheel
Exterior
Stock Mulberry Pearl paint
JDM Single piece Headlights
Factory Fog Lights
Red/Clear Tail Lights
94/95 Accord EX Front Lip
Suspension
Tein Super Street Coilovers (solid top mounts)
Stock 15" Alloys with 205/55/15 kuhmo ecsta asx (Winter Wheels)
Black 16" Rota Slipstream 215/50/16 Dunlop Direzza (Summer Wheels)
ESP Front + Rear Upper Strut bar and lower tie bar
ESP traction bar
Rear Disc Brake swap
Earls Stainless Braided Brake lines(rear)
Progress 22mm rear Sway Bar
40/40 prop valve
Prothane Master Bushing Kit
Brembo Rotors
Carbotech AX6 Pads
Interior
Pioneer 4 way 6x9 rear speakers
Sony Front Speakers
Arm Rest
Gutted Trunk
No back Seat
Huge update page 8 & 12
