engine codes and tranny codes
    guy w/ access to all data made this FAQ for us 4th genners
    http://www.honda-acura.net/forums/sh...d.php?t=206315
    Originally posted by 98CoupeV6
    This thread will list the DTCs (diagnostic trouble codes) with a brief description of it. To receive a more in depth explanation of the code and/or troubleshooting methods, please search the forum for that code or ask in my TSB/tech question thread.
    I HAVE A CHECK ENGINE LIGHT, ABS SRS LIGHT; HOW DO I FIND OUT THE TROUBLE CODE? For non-OBDII 4th gens, you'll have to bring the car to Honda or follow the following procedure:
    Reading Check Engine Codes
    Courtesy of Me
    EXTRACTING FAULT CODES:
    If the "CHECK" engine light has been reported on, you can extract the fault codes as follows:
    1) Turn the ignition on.
    2) Pull down the passenger side carpet from under the dashboard to access the ECU.
    3) Observe the LED on top of the ECU.
    4) The LED indicates a fault code by the blinking frequency. The LED can indicate multiple fault codes by blinking separate codes one after another.
    Fault codes 1 through 9 are indicated by individual short blinks.
    Fault codes 10 through 43 are indicated by a series of long and short blinks. One long blink equals ten short blinks.
    Add the long and short blinks together to determine the fault code.
    5) By connecting the two terminals of the check connector (located on passenger side under dashboard) with a jumper wire, the "CHECK" engine light will flash the same fault code(s) as the ECU LED. Don't forget to remove the jumper wire when you are done extracting the fault code(s).
    6) Note the fault code(s).
    Reading Transmission Codes
    Displaying and Reading Trouble Codes
    TROUBLESHOOTING PROCEDURES
    D4 Indicator Light And Transaxle Control Module (TCM) Locations
    When the A/T control unit senses an abnormality in the input or output Systems, the S indicator light in the gauge assembly will blink at equal intervals and the LED display on the A/T control unit will blink a problem code when the ignition key is turned on. However, when the Service Check Connector (located to the lower right of the glove compartment) is shorted with a jumper wire, the S indicator light will also blink the problem code when the ignition switch is turned on.
    When the S indicator light has been reported on, short the two terminals of the Service Check Connector together or pull the passenger's side carpet down from under the dashboard. Then turn on the ignition switch and observe either the S indicator light or the A/T control unit LED display.
    Problem codes 1 through 9 are indicated by individual short blinks, Problem codes 10 through 15 are indicated by a series of long and short blinks. One long blink equals 10 short blinks. Add the long and short blinks together to determine the problem code. After determining the problem code, refer to the electrical system Diagnosis By Symptom / Symptom-to-Component Chart . See: Testing and Inspection
    Some PGM-FI problems will also make the S indicator light come on. After repairing the PGM-FI system, disconnect the Back Up fuse (7.5 A) in the under-hood relay box for more than 10 seconds to reset the A/T control unit memory.
    TROUBLESHOOTING MULTIPLE INDICATOR LIGHTS
    The ABS/TCS and ATTS control units communicate with the ECM/PCM. If a DTC causes a loss of communication between two or more of these control units, the loss can cause multiple indicator lights to come on. For instance, when the ABS/TCS control unit stops getting data from the ECM/PCM, it sets a communication DTC such as TCS DTC 31 [engine retard command (PFINH) signal]. This DTC doesn't mean there's a circuit or control unit failure. It just means the flow of data between the ABS/TCS control unit and the ECM/PCM has stopped. If you troubleshoot the PGM-FI system or the ABS/TCS first, and clear the DTCs, you'll most likely fix the problem.
    As a general rule, troubleshoot DTCs that aren't related to communication first.
    For example, if DTC P1676 (FPTDR signal line failure) is set, and the ABS/TCS control unit has set a TCS DTC 24 thru 27 (TCS solenoid), troubleshoot the TCS DTC problem first.
    A second example: If the ECM/PCM sets a DTC P1498 (EGR valve position sensor circuit voltage high), and the ABS/TCS control unit sets a TCS DTC 31, you need to troubleshoot the DTC P1498 problem first.
    Accord 90-93 DTC Codes
    Engine Codes
    Resetting Engine Codes
    TO CLEAR FAULT CODES FROM THE ECU
    1) Turn the ignition switch OFF.
    2) Remove the Back Up fuse Fuse #24, 7.5A from the main (underhood) fuse box.
    3) Wait 10 seconds for the ECU to clear it`s memory, and reinstall the Back Up (7.5A) fuse.
    Transmission Codes
    I <3 G60.
    Yes, this is what I was talking about!!! Thanks wed3k. I just was not sure which car I saw this in.
      aweswome and helpful post....I'm all about it
      Former Ride:
      93 Accord Coupe
      Jdm H22 w/ LSD
      Type S pistons and cams
      New Ride:
      Bone stock 99 2.3CL
      Black on Black Leather
      5spd
      "Experience: that most brutal of teachers. But you learn, my God do you learn."
      C. S. Lewis
        its all in the manual which u can download it from the sticky.
        are we there yet are we there yet are we there yet
