Exactly as the title says. How would one go upon checking for codes? What tools and devices are needed? Where exactly do you check for the codes. What are the correct procedures? I know this is a newbie question and without a doubt, I'm one of them.
How do you check for codes?
This topic is closed.
http://www.honda-tech.com/zerothread?id=797528
Towards the bottom...in short just pull the carpet from your passenger side and count the flashes; a long flash is a 10 in the code and a short flash is a single in the code.
For example if it's long flash short flash short flash your code should be 12.
Then find your code here:
http://hybrid2.honda-perf.org/tech/codes.htmlNo more cb7, 7 years of ownership and 196K on the ticker before she was sold
Current beast: 98 ej8 on 7psi with a 15g turbo and other goodies!
NREMT-B | 300D and some glass
