Popping out of gear question
    Alright so within the last week or 2 of me having my car on the road it was popping out of 3rd alot, and then a week or so later the clutch finally died out. Now befoe I go out and spend all the money on an H22, pop it in my car just to find out my trannys bad... does anybody know if thast a sign of a bad clutch or a bad trans.
    Any input is greatly appreciated
    -Zach
    my second gear did that to me... tore apart my tranny (after replacing it first) and noticed alot of wear on my synchros and slide gear thing... so i'd say its your tranny
      Im considering saving my pennys for an H22 with trans swap. Or just sit on my money for a bit and pick up something else, my car has a bad leak up in front end and has soaked my carpit its a shame.
        Same exact story on my origional civic transmission. Second gear would just pop out if you let off the gas, and it ended up being a rounded off gear. I'd say its not the clutch because it wouldn't just do this in third.
          well, Im considering my options, right now it burns 4 liters a week when I could drive it, the roof leaks and has soaked the carpet, one of the quarters is quite soft... and the clutch is spent...dead.
          I dont really see any use in me resurecting it, Im almost 17 and only on a part time job. I was thinking of going with finding a civic si, or getting an eg hatch and putting a B16B or a D15B in it. just some ideas to throw around.
