I'm about to mill my head .020"-.030" and I've been looking at posts and a lot of people say the timing belt might not be tight enough? I was wondering if anyone here has milled their head and had problems with the timing belt? Would I need to use a different timing belt if I do this?
Also people say that you need to adjust your timing when you do this? Do they mean cam timing (need cam gears?) or ignition timing??
Thanks
Thanks
