Exterior:
Clear Corners and bumper lights, All red tail light conversion,
Hyper white bulbs, 2 front balding yokohama AVS ES100's
Ice:
2 10" audiobahns, Alpine 6 cd changer, Alpine deck,
Radio signal enhancer, 2 6.5" blaupunkts, 2 infinity kappa series 6.5"s
Interior:
R-spec pedals, Laptop, Power Inverter, Radar Detector
Engine:
F22a1 - Custom Weapon R Cold air intake
Turbonetics t3/t04E ball bearing turbo, 50 trim,.63 a/r, stage 3 turbine
h23a log style turbo manifold
Zeitronix Wide Band 02 sensor
Mandrel bent intercooler piping
T-Clamps
Starion Intercooler
Red Tial 35mm Wastegate
Red Tial Blow-off valve
Autometer Boost Gauge
dual gauge pod
Custom cup holder dual gauge pod
2.5"-2.25" custom downpipe
Chipped P06 on uberdata
dsm 450 injectors
Dr. Gas 2.5" - 3" exhaust adapter
2.5" Flexpipe
2.5" Glasspack
Megan Racing GT 3" exhaust
3" Stainless Steel Kteller exhaust
SS oil lines
Manual boost controller
walbro 255 lph fuel pump
2 oil catch cans
NGK 1 step colder plugs
Faze A/F gauge
Stage 3 6 puck clutch w/ Exedy Pressure Plate
8.8lb Fidanza Flywheel
Phenolic Intake manifold gasket
R-1 ground wire system
F22a6 dual runner intake manifold
coolant bypass mod
DIY short shifter
Energy suspension polyurethane rear motor mount other mounts filled with polyurethane
AEM camgear
K&N air breather
EGR block
Externally Coiled Dizzy with MSD Blaster Coil 2
Jackson Racing 160* Thermostat
Suspension:
kyb agx shocks and struts, neuspeed springs (2.5" front, 2.25" rear drop), Ractive Front strut bar, Front camber kit, Revotec rear strut bar, EX rear crossmember and rear sway bar
Not hooked up:
OBX Racing oil temperature gauge
OBX Racing water temperature gauge
OBX Racing oil pressure gauge
various pix of turbo setup
Possibly the best deal ever made for my car so far
Random pix of the car:
Ram air intake hybrid and proof that it does work...and yes that is a bird feather stuck to the top of the filter
Enery Suspension rear motor mount insert
i think thats the complete listing of my car, once i can get some axles and some sticky tires i can definately break past a 13.5 1/4th mile time. Thanx for
lookin and let me know if you need pix of something or have
questions about my setup
