LEGEND LIP INSTALL..
this is for peeps who need some help or insight in how put on/ install a legend lip.
suplies/tools needed
the lengend lip
6 bolts (a 3/8in. or 1/4in. bolts will work fine.)
12 washers for the bolts
10-12 screws preferably 1/2in long (i used sheet rock screws but sheetmetal screws will work too.)
a drill with a 3/8 drillbit or 1/4 drillbit.
blow torche or some sort of heat gun to heat up the lip to bend.
a tool box.
some wd40 or pb blaster or somehing like that.
a knife or saw
cardboard
starting off
first you should remove/ take off the front bumper.
to do that you must first take off the bumper lights to get to the 4 bumper support bolts (two on each side.) and the take off the two bolts on the inside on the engine bay. they are located below the back of the headlights. for the passenger side you will have the remove the battery support.
doing this will make the install easier to do.
you will need to cut some unneeded tabs off and some other little pieces off the lip. leave the top tabs. please read farther first.
intalling the lip
cut a small slit into the bumper to slide in the tabs that you didn't cut off.
the hole/slit sorry if the pics are crap at first.
bumper off/ tabs to save. and other spot to cut
cut the tab completly off.
mock up..
once you have it in the right spot and are ready to bend it put some screws in at the tabs near the center. also put one at the tab in the middle of the 3 top side tabs. the side tab/ one farthest from the center cut off most of it but not all. you will need to keep some on to put the bolts on later.
more in next post.
the lengend lip
a tool box.
a knife or saw
cardboard
starting off
intalling the lip
mock up..
more in next post.
