G23/g22????
    G23/g22????
    does anyone knw what type of engine parts do you need to combine to complete this motor? a chart would be fine.lol...will a H23 vtec head fit wit f22a6 block,with some work? or does anyone know about this combo?
    STUPID fucking idea.
    Why would you want a low-compression H22 with a 6500 RPM redline?
    Not to mention the difference in bore size, which will result in detonation-inducing hot spots...
    Plus, you can't make a G series using H and F parts. The G series has 5 cylinders.
      if you MUST know....
      http://www.importtuner.com/tech/impp...dge/index.html
      I <3 G60.
        When will the G23 bullshit die?
          when my car finally blows up
          instagram @mikeymeyagi
            Again?
              ha
              leaky headgasket doesnt translate to blown up sorry
                For most people it would... because they'd keep driving it until it blew!
                Yours hardly counts, though... you pretty much turned your F22 block into a sleeved H22 block.
                Either way, it's not a G series!
                  Be nice deeve.
                  My coupe!!!
                  Originally posted by Racer_XXX
                    I am nice. I'm saving this fool lots of time and money before he blows it all on an engine that's not worth building!
                      when swapping the head, the combo will drop your compression to 8.4, which is even more sarcastically stupid
                      but with a m2a4 and a good you could make 174.6whp, something a stock pt3 head will NEVER accomplish
                      on PT3 pistons NEVERRRRR!!!
                      so yeah im with the stupid crowd on this one
                      sorry deev love u man
                      Just do what PR CB7 said.
                        At what RPM are you making that power?
                        With an H23 intake manifold, a cheap header with a 2.5" collector mod, a decent camshaft, and a proper tune, a PT3 head would make that power as well. AND it will be more reliable. I don't care what the power potential is... if you can't keep it going for very long, it's worthless. MOST hybrids fail in a relatively short period of time. If I recall, yours failed, right? And you're not exactly a noob like most people that ask about it...
                          isnt therememebrs on this board that have accoplished those numbers plus some with stock f internals??? just curious where you get that from.
                          current cb 93 10th ann. edition
                          member ride thread >>> http://www.cb7tuner.com/vbb/showthre...73#post3257973
                            yes it did, i guess after 2 years on the block, 2 f22 heads, one ported, and finnally the h22
                            4 8k rpm burnouts, she finally started smoking from the rings, the bottom end never game me a problem
                            videos speak for themselves
                            http://www.myspace.com/video/vid/36450785
                            http://www.myspace.com/video/vid/36381867
                            i mean with the rate of idiots that read import tuner, publishing such a bad motor, and ive yet to see a f22 put out 175whp on a stock cam
                              Not on a stock cam, no... but even a $100 Delta 272 would make a big difference, and be far more reliable than most hybrids. 272 = $100. 2.5" collector mod and cheap header = about $200. P06 = $30, plus $20 for a chipping kit. H23 IM is about $75 in most cases. Then tuning costs whatever... For roughly $500, I'm sure that setup would make plenty of power.
                              Also, 174.6whp from an H22 head on an F22A block? Would you care to explain to me how a hybrid motor with CONSIDERABLY less compression than an H22 would make 10whp MORE than a stock H22?
                              That's like saying "Man, that NBA player sure can dunk... but let's chop his legs off at the knees. He'll be even better!"
