Ok I just did a headgasket on an engine. I had to swap the block b/c it was so badly corroded that the headgasket wasn't sealing so, basically the entire engine is new.
I'm getting good compression, and I'm getting spark, but there's no fuel in the rail. I also put some gas in the tank b/c it was sitting for about 5 months when I finally finished it last night.
I pulled the main relay, took the cover off and checked all the solder joints are good. I also heard it click prior to taking it off the car when I turned the key to the ON position.
Does that mean the fuel pump is bad? I don't hear it turning on at all when i turned the key to the ON position.
