Foglight Switch + APC Wire Harness?
    I know this isn't the right place, but I REALLY need to figure this out.
    I'm running an APC Foglight wire kit. I have a red wire, white wire, and black wire hooked up to a small little temp. switch for now.
    How would I go about wireing those same wires to the OEM fog switch? Or can I even do that? Or is there a way around it or what?
    :::Jeremy
    [ My Car Domian ] - [ My Members Ride Thread ] - [ Facebook ]
    My Top CB7Tuners :
    TypeG
    aww_shiet
    91accordexr33
    Originally posted by Ralphie
    I still don't understand.
    Is there anyway I could just hook the three wires to the certain prongs in the switch to get it to work?
    :::Jeremy
    My Top CB7Tuners :
    TypeG
    aww_shiet
    91accordexr33
      you could play with it and see what happens
      im guessing that since you have 3 wires one is power one is ground and maybe a constant or something?
      Im not good with wiring but im sure it can be done.
        I have the same setup, I can help joo
        I will go to car and get said harness
          Note: Join all your connections with solder and wrap each with electrical tape. Do a professional job.
          -I made my "To Pin #2" wire out of 2 wires, this is unnecessary.
          -Join the 2 grounds to the black wire on the aftermarket wiring as seen here.
          -Black goes to Red, which goes to Pin #3
          -Red/White goes to white, which goes to the "turn-on wire"
          -Red/Orange will lead to your wire leading to Pin #2
          -Note A: This ground is inside the cabin. Ground it to the upper mounting bolt of your hood release latch.
          -"To Pin #3" goes to pin #3 on your fuse box (by the drivers foot)
          -The white wire runs from the cabin through a hole in the firewall to the engine bay.
          -I prefer to ground the 2 black wires there to the wire that runs directly from the Negative terminal on the battery to the chassis. Anyway, ground them to the chassis one way or another.
          -The white wire that goes to the 12v power source can run to the battery directly or, as I preferred, to the + wire that meets the under hood fusebox.
          Using this setup, the foglight button lights up correctly and the fogs can operate with the highbeams on or off.
            ill help ya do it this weekend or whenever u come back over ^_^
            ttl
            [COLOR="Magenta"]
