fast93accord : 1993 Accord 10th Anniversary
    I think most people here have seen my ride, but for those who havent there it is.
    Ok, so heres a little history about my ride. 1993 Honda Accord 10th anniversary edition. 4 door. Car was previously nitrous fed on the F22a/automatic. Then i went with a 14b turbo/35shot/auto. An oilseal in the turbo failed, and spit oil into the combustion chamber while making 14psi and 2 piston ringlands broke.
    So, my car spent 7 months in a friends garage while i built the beast it is today. I built this car to prove that you dont need 2 cams or vtec to maka 4cyl fast.
    Ok, my engine is an F22a. I got darton mid-sleeves installed in it. Honda OEM bearings. OEM F22a crankshaft. Crower F22/H23 connecting rods. Race Engineering (wiseco) extreme duty 8.8:1 forged pistons. I went with 85.5mm pistons.
    We had some issues with sleeving the block. The place that did it cracked 2 blocks before they got it right... was a major pain in the ass...
    I've had some headgasket issues do to the power level but i think i have them resolved. I was using the OEM headgasket with the .5mm oversized pistons. People say it works, but the gasket was in the cyl a tiny but. So after 2 blown headgaskets I put ARP H23 headstuds in, and put an OEM honda F23 headgasket(slightly modified). Its been a week and all seems good.
    [IMG]
    I spent a looooooooooooot of hours on the cylinder head, and that bitch flows... I am using new OEM honda F22a6 valvesprings. KMS stainless valves. and a Delta 272 camshaft. I have an F22a6 lower intake manifold, with an H23 upper and throttlebody. I spent a looooooooot of time on that also. It is completely gutted on the inside from top to bottom. Gigantic plenium.
    I used a dsm style cast turbo manifold on this. The turbocharger is called the SBR-M60. It has a mitsubishi watercooled standard bearing section. It has a 60-1 compressor wheel. 3"inlet, 2.25"outlet. The turbine wheel is the TD06H. The turbo also has a 38mm internal wastegate.
    Getting this turbo to fit took a lot of grinding. I had to clock the compressor a hair, and grind out the webbing off the block, and grind off the nubs for the torque arm on the block.[IMG]
    http://www.imagestation.com/picture/sraid167/p227fe1757a0784a7511a85cc27eb243f/f43443d1.jpg[/IMG]
    The intake pipe is by Dejon Tool for a 1g dsm w/o mass air. The o2 housing is by Victory Performance Custom 2.5" stainless downpipe for now... and Greddy SP exhaust for now... Need custom 3" dp and exhaust...
    The intercooler piping is 60mm. I pieced it together myself... The intercooler is a Spearco. It is 3.5" thick
    The car used to be an auto. I now use an H23 5spd. ACT streetlite flywheel. ACT XTSS clutch.(still holding good) stock accord 5spd axles. Modifed trans mount. No torque arm. 92LX 5spd rear mount with insert. MT drivers side mount.
    When it came to tuning i knew i needed something good. So i went with the AEM EMS 1040u with built in wideband controller. I cant emphasize enough how much i love this computer. You can do anything you want with it plus more then you could imagine. I also use Fuel Injector Clinic 850cc peak/hold injectors, Walbro 255 fuelpump, AEM 94-97 accord fuel filter
    I am also using a GM 3bar map sensor, and a GM boost control solenoid. Sparkplugs are currently NGK BKR8EIX.
    I currently run 15psi and it is a beast. All it does is spin tires till 70mph. And from 70-90mph in 3rd gear it still spins a little. I'm estimating the car is making 375whp right now. I took it to the dragstrip one time with boost at 12psi in 1st-3rd and 14psi in 4th. Full interior/exhaust. I use 24.5" slicks. Launcing at 4k with 7psi it bogged. Granny shifting it at 6000rpm i ran a 13.2 at 111mph with a 2.1 60ft. 2nd pass i took off the air filter. Bogged again out of the gate, but shifted at 7000rpm this time. At the 1/8th mile i had 2mph over the previous run but i grinded 4th gear and ran a 13.7...
    Right now with 15psi i feel the car should go mid to low 12's.
    I do plan to run over 20psi on racefuel however. I expect 425whp at 20-22psi and some easy 11 second timeslips. I do plan to gut the car out and run open downpipe.
    I also want larger exhaust, i/c piping, and t/b, but thats for the future. One recent addition is a Moroso H22/H23/F22 oilpan. I also use a special turbo oil filter/ .065" restrictor. When i built the bottome end i elimated the balancer shafts with a Kazzen speed full kit. This consisted of plugging the oilpump/block, and drilling/tapping the block. Was a pain in the ass. The car makes insane oil psi. When fully warm it makes 35psi at idle and 85+psi cruising and even more at WOT.
    Oh, i also have a Nitrous Express wet kit installed with a 35shot on there. The car is so fast at 15psi i dont plan on using the juice anytime soon.
    I'm trying to think if thats it... all i can think of right now. Anyway enjoy.
    PEACE
    12.5 at 114.6mph 15psi
    11.7 and 11.5 20.5psi
    F22a1
    60-1 td06h turbo
    Darton mid sleeves
    85.5 wiseco 8.8:1 forged pistons
    Crower pro billet rods
    Custom ported head.
    KMS valves
    F23 headgasket
    ARP H23 headstuds
    H23 upper intake manifold
    Intake manifold is gutted
    AEM EMS 1040u
    FIC 850cc injectors
    Walbro 255 pump
    H23 manual trans
    Prelude shifter assembly
    Forbidden short throw
    Nitrous Express Kit installed, never used on this motor
    looking good man, nice numbers...lets see some pics of the entire motor with the turbo and the rest of the car...good job so far man...way to build the motor first!!
      The man speaks the truth.
      I think i have some pictures some where....imma up them.
        wow that is one quick car you got there! very VERY nice job on building the motor. you don't always see that kind of extensive work and time. we all should learn from you.
        btw, please abide by the forum rules and post correctly. http://www.cb7tuner.com/vbb/showthread.php?t=279
        1cor10:31
        - 92 LX coupe
        - 96 EX wagon (sold)
          i got to see more pics on that car (basically the motor and the rest of the car) nice work. i cant say anymore
            mmmm....Turbo.... That's the way to rep a SOHC right there! Mad powa!
            Automotive Service and Fabrication In SOCAL!! https://www.facebook.com/JLRFAB
              good well done...lovin every bit of it...makes me wanna keep the SOHC now
              lets see some 12's!
              Formerly 91AccordExR33
              11.68 @ 127mph
              417whp/375wtq
              Sold: 8/2016
                got more pics? of the engine bay after installation
                92 accord dx....traded
                97 accord ex....traded
                93 civic si ....stolen
                96 tercel ....sold
                97 ek hatch b17 ..traded
                97 civic 4door b16 sold
                04 tsx traded ...for a honda coupe (top secret)
                  Here they are.... These are the ones i got.
                  I can get a photoshoot going if Adam would like....
                      very freakin nice dude......amazed....great job on the engine. someone who does the job right the first time!!!!!!!!
                      My members ride thread
                        that thing is a beast
                        I hate thieves!
                          wwwwwwwwwwwwwoooooooooooooooooooooowwwwwwwwwwww!
                            tha's nice.
                            Audi A4 2.8 Quattro Sport
                              i need to take some new pics of it. They engine is crooked in those pics... It sits level now, and the wiring mess is finally under control...
                              Some other things about the car, It is on the stock suspesion. Plan to get coilovers. The brakes are 4 wheel slotted rotors all around. Tires are way oversized on OEM rims. Tires are off a 2004 accord. i think 205/65R15.
                              F22a1
                              60-1 td06h turbo
                              Darton mid sleeves
                              Custom ported head.
                              KMS valves
                              F23 headgasket
                              ARP H23 headstuds
                              AEM EMS 1040u
                              FIC 850cc injectors
                              Walbro 255 pump
                              H23 manual trans
