ok so i have had this clunking noise when i accerate, that sounds like it is coming from the left side of the motor, but i could be wrong. So i replaced both drive shafts, and it still was making the noise. Next i figured i would do a tranny flush...and to no suprise, it still did it. and yesterday i put in a new rear motor mount cuz it was shot and i figured maybe that was it. NOPE! still does it. It almost seems like it is getting worse, but that could be my imagination also. Any ideas of what to do next would be great. Thanx guys, you have bailed me a out a few times, lets hope u can do it again.
clunking noise won't stop!!! HELP!!!!!
check all suspension components incuding sway bar links and bushings.
Disregard females, acquire currency.
My 2003 Nissan Maxima Members Ride Thread
DIY: HOW TO POST PIC(S)
describe the clunking and is it more of a ticking or metal to metal deal i doubt its your axels it could be a broken spring you just replaced the axels so this shouldnt be bad already if its nothing suspension related id say its internal sit still and rev the engine to make sure thats not the problem it could also be internal on your diff on the trans bearings do go bad after a while it just happens
Originally posted by HF22Tdescribe the clunking and is it more of a ticking or metal to metal deal i doubt its your axels it could be a broken spring you just replaced the axels so this shouldnt be bad already if its nothing suspension related id say its internal sit still and rev the engine to make sure thats not the problem it could also be internal on your diff on the trans bearings do go bad after a while it just happens
I have this problem too. It got louder as my axle got worse. I'm hoping that's what it is.
It might be a transmission problem though. I did my mounts and the clunking remained.
Originally posted by lordojaim with you on that one bro! aint nothing beat free food and drinks any day of the week, even if its at a funeral
If it does it with it in gear it is most likely a mount or some bushings.
Have you looked at your radius rod bushings?
How about your upper control arm bushings?
Balljoints?
Tie Rods?
Strut mount bushings?
Rear engine mount?
You have 4 mounts and any combination of them could be bad with the age of the car.
