Little intake filters??
    is it better to have them breather filters or just have the holes from the engine to the intake? whats better and why?
    The two little filters in the pix. one on the intake and one on the engine
    breather filters
      Originally posted by HondaB18
      breather filters
      x2 keeps any kind of debris and other garbage that could damage your motor out. Later
        Do it right and get a catch can.
        The New-ish Ride
        My old Ride
        Hear my Vtak!!!
        MK3 Member #3
        I piss off people for fun.
        IA 08 Sunburn Victim #1
          X2 , recommended and better than breather filters.
          1996 Honda Civic LX 2009-2012
          2012 Kia Optima LX 2012-2013
            also, 2 of them aren't needed, as you could put a vaccum cap on the intake tube and save $10 . later.
            Avoiding dirt at all costs
              catch can.??? ok and that is what?
                http://www.cb7tuner.com/vbb/showthre...ighlight=catch
                later.
                  ok so i guess am suppose to make this ghetto thing then lol. but like i asked before what is the purpose of a breather filter or even a catch can? why do people usually put them on there car?
                  just want to learn more and more about are honda accords.
                  Thanks alot.
                    keeps oil out of the intake
                      You could always just hook up the stock lines :/
                      ..It's not cheap to build a fast CB7, especially NA. However, if you're willing to put the money into the car, it's well worth it in the end. There ARE faster cars out there, but some people, like me, want THIS particular car to be fast!...
                      Sold to:tanNn2koo,9tAkord,ThrakBarts,nahmo,andrizzle,or anger
                      Bought from:93a-lude, bruno8747, soysauce
                      1993 H22A cb7 <3 miss you
                      04 WRX stg 2 sedan
                      Current - 02 WRX stg 2 wagon
                        why not just put the breather filter and clean it out every once in a while like i do with the regualar filter on the intake. clean it out with the intake cleaner and spray.
                          Breather Filters can cause lost in power. Putting a breather filter on changes the pressures within the PCS valve resulting in less pressure to the crank and in return more positive blow-by which can result in the loss of cylinder pressure.
                          The oil catch can is recommended over the filters. The filters are cosmetics and both are not really necessary on a stock engine.
                            o ight. ok so it can cause lost of power but its not something that is a known fact then. and yes this is something i want to put a on stock engine just to help it out and give it a longer life.
                              it dont sound like your reading, its not going to help any might loose power, might get oil in engine bay, have to clean, cost money, there are better solutions, just dont do it plus its not going to make engine last longer.
                              now if you wana put it on just for looks or kicks or what ever the reason is, then do it. it looks hot tho
                              Not my fault my dick only fits magnums.
                              Why drink and drive when you can smoke and FLY?
