i was wondering where can i get the transparent orange paint so i can paint my cornerlens amber? cuz i painted mine red and i got pulled over for it yesterday so i wanna change it to amber color so they can dismiss the ticket. aite thanks
amber corner lens? paint?
I used kyrlon stained glass spray paint sold at michaels, hobby lobby and other hobby stores. Should run around 3-4 dollars a can.
Make sure you clean the lense really good then use 3-4 light coats (allowing to dry in between coats) for you liking of amber.
I used 4-5 coats for a more orange look. and I used the yellow stained glass paint because the orange after a couple coats will look dark red .
Pic is in my sig or if you want more here you go:
http://www.honda-tech.com/zerothread?id=854774No more cb7, 7 years of ownership and 196K on the ticker before she was sold
Current beast: 98 ej8 on 7psi with a 15g turbo and other goodies!
NREMT-B | 300D and some glass
you need this thread here:
http://www.cb7tuner.com/vbb/showthre...=amber+corners
all you need is a simple search sometimes (amber corners).
