Hey I've had my 91 EX for about 8 months and I'm ready to start the mods =]. But I'm new to this whole thing and pretty much have little to no knowledge. I was going to start with the basic header, exhaust, and intake upgrade. But what do you guy think would be better, cold air intake or short ram intake?
Cold Air Intake vs. Short Ram Intake
http://www.cb7tuner.com/vbb/showthread.php?t=155493
NY
Follow @cb7_society on Instagram
h22 swap fund - $24.95Tags: None
I've researched both of them, but I don't see any real difference between them besides length and hp.http://www.cb7tuner.com/vbb/showthread.php?t=155493
NY
a cai will give you a denser air charge in most cases leading to more hp. sometimes it will even "trick" the ecu into runing leaner. longer tube = more friction.
a short ram draws warm air from the engine compartment but in most cases allows for a higher velocity of incoming air.
its all up to personal preference, if you drive through deep ass puddles because you live on a back road or something you might not like a cai due to the whole hydrolock thing, if you live in a warm dry climate you might not like a short ram. its all up to you, cheif.Last edited by scudweiser; 06-21-2009, 11:47 PM.
longer tube doesn't equal more friction, very little of the total volume touches the tubing.
Longer tubing effects air resonance...I don't understand it fully so I can't really go into detail...but apparently you want 2-3' of tubing? I'm not sure I need to learn more
once you get moving temperature inside is a null argument...but you still want to get the air from the fender...basically not in the engine bay...it helps...but not by much.
it's the larger tubing plus less restrictive air filter that helps...cause those two let in more air.____
Thank you all for your help! So basically the short ram intake will increase the torque and cai will raise the overall power? Correct me if I'm wrong.http://www.cb7tuner.com/vbb/showthread.php?t=155493
NY
And as a btw, my car is automatic. Should I even do any mods on an automatic car?http://www.cb7tuner.com/vbb/showthread.php?t=155493
NY
Originally posted by tweezy View PostAnd as a btw, my car is automatic. Should I even do any mods on an automatic car?
as far as SRI vs. CAI. its not about how much hp you get. the only difference would be about like 1-3hp difference. its more about WHERE you get the gain at in the power band. a SRI, you'll get the low-to mid range power. being that the tubing is shorter and the filter is closer to the TB, the air gets to the motor faster.
but with a CAI, the power is gained in the mid- to top end range. the tubing might be longer, but it helps the motor breathe better on the top end with colder, denser air from the front bumper at higher speeds.
but if your in a area that has more rain than dry days, it would be best if you had a 2-piece intake. thats only if you want the CAI gain, but dont want the water to be sucked up into your motor on rainy days, you can take the lower portion off and use the SRI.
Originally posted by hella_fresh View Postits just a intake. gives you tops 5whp, so dont blow to much money on it. you barley will feel it. just my opinion
also every little bit counts...not everything gains 10 or 20+hp...it's a cumulative effect. Besides 1-3 consistent hp for $19...not bad...plus a better breathing engine...and it sets you up for future mods...like a cam...and tune____
Originally posted by 5gwagon View Postmore or less cai is a ricer mod, good for sucking up puddles. i learned my lesson on that the hard way
and it only sucks up puddles if you put it too low...that is an improper installation issue...also called...user error____
