I've seen several people ask about this and I havent found an answer myself either. How and where do you install the washer on the rear to correct the camber? A picture is worth a thousand words! How many should be put on? Any help would be great
Rear Camber washer question?
Jack up the car and u will see a bar bolted to the chassis by 2 bolts. (look above the tire in the fender well) Loosen the 2 bolt and put the washers in between the chassis and the bar. If u need more than 2 washers to straighten the camber, get longer bolts.
PURCHASED NOVEMBER 1991. THAT'S RIGHT, I'M THE ONE AND ONLY OWNER. BEAT THAT!
