wasup, well will be doing my swp in the ext month or two and wanted to know about power steering, can i run my car with out it ? i mean i have seen it on civics before where the 2 lines that run to the pump get taking out and just run them back into the rack, dunno if this can be done on the accord ? can anyone confirm ? tia
wanting no power steering
You sure can. For now, take the belt off. Taking the belt off yields the steering hardest b/c it's still a full cycle system and when you steer, you're pushing fluid around back to the pump, giving you more resistance. Looping the lines together is alittle easier. And the 3rd way, which is awecome, can be viewed here:
http://cb7tuner.com/vbb/showthread.p...teering+manual
It's a great thread, and it's basically putting a breather at the top of the loop, which the venting makes the steering even easier! I'm going to do this eventually. Good luck w/ your swap and everything else
Yes it can be done. There are many ways to do it.. just re-routing the lines, connecting them together as they are, or taking them all off and connecting the rack ones directly together. If you really want all the answers now, and see how other people accomplished it, click on that little button that says "search", its so underrated but can accomplish quite a bit.
