Bolt pattern after 5 lug swap
    Well, I've been reading a bunch of DIY's on how to do a 5 lug swap on both the front and rear, and the parts lists are usually off of a Prelude or an Odyssey.
    Is the 5 lug bolt pattern on both cars the same? Are they all the same, for that matter? Or what, exactly, is it?
    Believe they are the same, but if you check out www.tasauto.com (site sponsor) I'm sure you will find your answer
      All 5-lug Hondas, until recent 2010/11/12 models, have been 5x114.3
      Originally posted by Jarrett
        or not. Lemme quote the site. "90-02 Accord parts are all we do"
        this gives no info on the odyssey/prelude.
        to answer your question yes the odyssey knuckles 95-98 that fit the front are 5x114.3
        and the rears are whatever you get. if you go with 97-01 lude hub and bearing, then again 5 x 114.3
        MadLab Racing
        Southern Maryland
          Now, on to part two of my question:
          If/when I do the 5 lug swap for both front and back (trying to be uniforml), when I go to get pads/rotors, I'll have to get them for the model and year I got all of the swapped parts from?
          And I'm sorry for bringing up a vague subject, but as far as the prelude parts swap goes... I read an article about the position of the brake caliper and pads and the effectiveness of said parts when swapped from car to car.... I could be and probably AM wrong, but I'm just wondering if anybody else had read the same thing.
