Hello all,
I have been running the h22a now for a few weeks without the butterflies hooked up to vacuum (always open) and was expecting my new air box (broke a nipple on the other one) early this week. Well it never came so I called majestic and it turns out they are on back order and it will be a few weeks.
At this point I said ok well I have an old vacuum box from the f22 and what the hell. So I hooked everything up turned the car on looked under the hood and... Nothing.
So I double checked that the vacuum lines were run correctly and they are. So I got out the trusty multimeter and checked the voltage at the solenoid plug. I got a voltage of 4.9 something. So I figured it was getting supplied correctly. So took the resistance of the solenoid and got like 29. something (don't remember exactly but something like that). So at this point I am going well what the hell.
If I run the butterflies directly to vacuum they close, so the diaphragm is ok. I am getting vacuum to the solenoid, but it is not opening when the 5 volts is being sent to it. I have also used another solenoid and same thing.
I have verified that it is hooked up to pin A17 and that it is connected to an ignition source.
Help! I am almost out of ideas here guys.
If someone out there would be kind enough to measure the voltage between the two wires going to their working IAB solenoid I would greatly appreciate it. Anything you can think of would be nice too.
Thanks.
Thanks.
