For all of you who have your secondaries controlled directly with a vacuum line: I took a long piece of tube and watched my secondaries as I was driving, and direct vacuum controlled is definitely robbing you of power unless you're WOT all the time......check these out.
Video 1
video 2 - shows valves a little better
I had the valves opening all the way on moderate acceleration in 2nd and 3rd as low as 2000rpm-redline. My deduction is that hooking the controller directly to the manifold will make your bottom end suffer because you don't have good flow velocity to mix the fuel up well.
Video 1
