Could someone please help me find where this unit is located? thanks
DRL unit location?
most of us would'nt know as we have usdm cars, but imma take a wild guess and say that the relay is located above the gas pedal, way up there. You will have an easier time if you remove the dash panel from the drivers side first; It pulls out with clips. Start on the corner and work your way over.
Look for the plastic grey box with the BLUE connector. somewhat like this:
Purchased from: 90-JDMCB7, cb95spd, 92_dr_p, ukaccord92, slammed4thgen, 93a-lude, h22anow, cb7addicted, H22WAGON93, tonymontana1204, agol, Joshy
Sold to: di2accord
Originally posted by KRIS05VVTi View Postmost of us would'nt know as we have usdm cars, but imma take a wild guess and say that the relay is located above the gas pedal, way up there. You will have an easier time if you remove the dash panel from the drivers side first; It pulls out with clips. Start on the corner and work your way over.
On the 4th Gen its under the dash, driver side.
By where the cruise control, Main relay would be.
jaxs right. you can pull it off with a 10mm
93 Accord LX Sedan (sold)
ressurection mwahaha
is that the lil fella thats been causing me to not have highbeams at night? with drl indicator onhttp://www.cb7tuner.com/vbb/showthread.php?t=167601 Click to see my new ride
hi guys for jack frost whites theory...i tried taking out the that realy on my 4th gen....But the promblem is now, i no lights to run on even if i turn on the headlights...it won't turn on...so i have to put it back.....how would you do this...Im such a nooob.!!!!!!!!VS
Mercyboy: I rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
MERCYBOY THREAD:http://www.cb7tuner.com/vbb/showthread.php?t=158241
1990 RHD Honda accord si CB3 Canada http://www.cb7tuner.com/vbb/showthread.php?t=196287
MY CB7 ON YOUTUBE: http://www.youtube.com/watch?v=CJID_IxwiNY
